No Power to Radio Or Heater - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 2nd October 2011   #1
Bernie7839
Bernie7839 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hello,
Ive recently bought a 1998 Megane Coupe 1.6 as a run about, i quite like it so ill probably keep it for a while! Main problem i have at the moment though is there is absolutley no power to either the Radio or the Heater, however the Digital Clock works, which i thought would have run off the same circuit.
Ive done the basics, checked all the fuse banks and relays but everything seems fine.
Any Sparky Guru's able to point me in the right direction?
Cheers!
Bernie7839 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Bernie7839
No power to Engine. Megane Electronics Storeman001 5 1037 4th October 2011 06:04 PM
Megane 1, 1.6 ICV Pic request Engines bobbydog 1 792 2nd October 2011 10:25 PM
No Power to Radio Or Heater Electronics keat 5 944 2nd October 2011 10:24 PM
Sponsored Links
Advertisement
Old 31st January 2012   #2
keat
keat is
has no status.
Member
keat's Avatar
Re: No Power to Radio Or Heater
Guys.
Has anyone got any ideas on this. Mine has just started doing exactly the same today. I'm guessing an earth wire, as it's intermittant and works when you go over a bump and such.
Currently in keat's garage:
http://www.cabletiefan.co.uk
keat is offline   Reply With Quote Quick reply to this message
Old 1st February 2012   #3
mord
mord is
not a complete idiot, some parts got Leftbehind,...(in the UKraine)
Platinum member
mord's Avatar
Nominated 2 Times in 10 Posts
Nominated TOTW/F/M Award(s): 3
check the 20 and 40A fuses in the passenger compartment.
do a search for MR312MEGANE6 doc online it has the aircon faultfinding for your car.
there are some bits of the aircon system under the scuttle panel, relays, power modules etc... check there.
Currently in mord's garage:
The CreditCard Holes sooo DEEEEP NASA have put up warning signs about a black hole on the Driveway: update, the driveway and home have fallen in...
mord is offline   Reply With Quote Quick reply to this message
Old 1st February 2012   #4
keat
keat is
has no status.
Member
keat's Avatar
Has anyone got a list of fuses for the MK1.
The user manual isn't much help trying to identify what is common the both units.
Old 1st February 2012   #5
keat
keat is
has no status.
Member
keat's Avatar
Typical. I got home from work to have a quick look.
Turned on the ignition, Radio, Heater Blower and Clock/Temerature Module in dash, not working.
I started the car, and they all came on.
The spring has gone in our ignition switch.
Does anyone know if the spring is part of the lock mechanism, or part of the switch which is screwed to the back of the lock.
Maybe it's related ??
The Haynes manual isn't much use.
I've scoured the wiring diagram and am struggling to find any one thing which is common to all units.
Reply
Tags
heater, power, radio
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
