Renault Can Clip Fault codes - Page 2 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 13th November 2011   #6
horne65
horne65 is
Cars don't you just love them!
Diamond member
Threadstarter
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Re: Renault Can Clip Fault codes
Quote:
Originally Posted by kini View Post
Not a complete list but htis is as good as it gets:
click on the link to know what the fault codes mean/solution
http://www.permoveo.ltd.uk/tabid/123...t/Default.aspx
I don't know what these codes are from but they do not corespond to any codes the the Can Clip throws out.
Currently in horne65's garage:
One Laguna ll, 2004, 1.9dci, One Clio 1.5dci 2005 = 100bhp, 2014 Corsa 1.4 Turbo, 2011 Audi A1 1.6 Diesel
horne65 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 13th November 2011   #7
mik260
mik260 is
has no status.
Junior Member
mik260's Avatar
Those are OBD codes. Can clip uses Renaults own codes.
Currently in mik260's garage:
2002 Renault Scenic I Phase II Expression 1.9 dti 80 bhp
mik260 is offline   Reply With Quote Quick reply to this message
Old 13th November 2011   #8
horne65
horne65 is
Diamond member
Threadstarter
Quote:
I don't supose anyone has a list of all the Renault Codes?
Old 13th November 2011   #9
mik260
mik260 is
has no status.
Junior Member
mik260's Avatar
Try the .pdf files in /technic/DiagAssi/Diagnostic
Old 13th November 2011   #10
cb3
cb3 is
has no status.
Diamond member
Fuel(diesel) Injection codes.
DF001 Coolant temperature sensor circuit
DF002 Air temperature sensor circuit
DF003 Atmospheric pressure sensor circuit
DF005 Engine speed sensor circuit
DF007 Rail pressure sensor circuit
DF008 Pedal potentiometer circuit track 1
DF009 Pedal potentiometer circuit track 2
DF010 EGR position sensor circuit
DF014 Vehicle speed information circuit
DF015 Main relay control circuit
DF016 EGR control circuit
DF017 Preheater unit control circuit
DF024 Low-pressure actuator control circuit
DF025 Preheater unit diagnostic connection
DF026 Injector cylinder 1 control circuit
DF027 Injector cylinder 2 control circuit
DF028 Injector cylinder 3 control circuit
DF029 Injector cylinder 4 control circuit
DF037 Immobiliser
DF038 Computer
DF039 Inlet air temperature sensor circuit
DF047 Computer supply voltage
DF049 Refrigerant sensor circuit
DF050 Brake switch circuit
DF051 Cruise control/speed limiter function
DF052 Injector control circuit
DF053 Rail pressure regulation function
DF054 Wastegate control circuit
DF056 Air flowmeter circuit
DF057 Water in diesel detector circuit
DF059 Misfiring on cylinder 1
DF060 Misfiring on cylinder 2
DF061 Misfiring on cylinder 3
DF062 Misfiring on cylinder 4
DF089 Inlet manifold pressure sensor circuit
DF098 Fuel temperature sensor circuit
DF107 Computer memory
DF112 Cylinder sensor reference circuit
DF113 Sensor supply voltage
DF114 EGR solenoid valve circuit
DF116 Multiplex network
DF121 Accelerometer circuit
DF122 Supply voltage pedal potentiometer track 2
DF130 Flow capacity function
Currently in cb3's garage:
2004 Megane 1.5dci
cb3 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to cb3 For This Useful Post:
pelikinesis (27th January 2013)
Reply
Tags
clip, codes, fault, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
