reason for oil in air filter - Clio II '03 1.2 16v - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 20th November 2011   #1
thepointmisser
thepointmisser is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Im having the notorious engine idle problem...fluctuating idling/juddering gear lever etc...and oil in my air filter..
What i want to know is if the idling problem and the oil in the air filter are related, and in any case what is causing the oil in the air filter and how do i cure it??
When i was having a look about it, i took off the airbox cover and noticed oil inside, and the lower part of the filter was covered in oil. I removed the filter entirely and havent replaced it yet. Coincidentally perhaps, but the idling problem hasnt happened!
thanks
Currently in thepointmisser's garage:
'03 clio
thepointmisser is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by thepointmisser
reason for oil in air filter - Clio II '03 1.2 16v Engines madnoel10 2 2879 20th November 2011 11:36 PM
idling problem 1.2 16v '03. Engines thepointmisser 4 1460 3rd November 2011 08:12 PM
'04 clio II are there 2 x alternator belts? Engines wahwahboy 13 2880 22nd November 2010 05:17 PM
Mk 2 Clio Headlight Height Adjustable? Electronics owenfackrell 3 1299 12th June 2009 02:47 PM
Sponsored Links
Advertisement
Old 21st November 2011   #2
thepointmisser
thepointmisser is
has no status.
Junior Member
Threadstarter
Re: reason for oil in air filter - Clio II '03 1.2 16v
i fear i have discovered the answer to my own question from a previous thread i just came across...PCV Valve perhaps?
I have NO IDEA what this is, but i have three questions..
1.Is it MOST LIKELY to be this PCV valve?
2. is it cheap or easy to fix?
3. If it isnt looked at is this a VERY BAD problem!?
'03 clio
Old 21st November 2011   #3
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Ol in the air inlet system is usually down to a faulty PCV valve.
Depending on the engine type it will be located either in the breather pipe or the rocker cover.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Reply
Tags
16v, air, clio, filter, oil, reason
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
