"Air Bag Off" warning on Laguna - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 12th December 2011   #1
simoncollins
simoncollins is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have just progressed to my 5th Laguna (am I normal?!?!) - a 56 plate 2.0 Privilege
On the dash there is a warning light which flashes on briefly stating "Air Bag Off"
From the manual I think this means the passenger air bag has been manually disabled - presumably from the switch in the end of the dash by the door hinge?... but changing the switch doesnt appear to make any difference
Have I read the manual correctly or is it just a warning to make you think in case you want to turn it off (carrying a child seat etc)?
I am assuming its a fault I need to get looked at? If so is there anything you experts can suggest I check
Thanks as always in anticipation
Simon
Currently in simoncollins's garage:
2010 Laguna 2.0 Dynamique Tom Tom... Laguna #6 :)
simoncollins is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by simoncollins
Updating Laguna sat nav Electronics simoncollins 2 276 26th October 2015 11:06 PM
Megane - clicking before ignition?? Electronics Meganeman 1 501 26th March 2014 11:13 PM
Removing Clio (2005) heater panel Heating & cooling simoncollins 0 576 28th November 2013 07:25 PM
Airbag + Service light on 52 Megane Conv Electronics simoncollins 2 877 18th June 2013 10:43 PM
N/S Rear door card on Laguna II Interiors mord 3 917 20th January 2013 02:30 PM
Sponsored Links
Advertisement
Old 12th December 2011   #2
Azurael
Azurael is
<|---Knee--<<<
Platinum member
Azurael's Avatar
Nominated 0 Times in 2 Posts
Re: "Air Bag Off" warning on Laguna
Wow, somebody who's had more Lagunas than me!
It's definitely supposed to go off if the switch is in the off position, I'd check that the switch is working properly and check the continuity of the wiring with a multimeter (obviously, disconnect the battery for ~10 minutes before touching anything connected to the airbag computer Or better still, disarm the system with CLIP if you can)
I haven't had one with the option to disable the passenger airbag yet, I think that came about in 2002/3. Can't see myself needing to put a child seat in the front of my car so it's one less thing to go wrong
__________________
All murderers are punished unless they kill in large numbers and to the sound of trumpets. - Voltaire
Currently in Azurael's garage:
TEB64 (Cosmic Grey) 2001 'Y' Laguna II 1.8 16v Privilege Tourer (KG0B F4P-770)/TED44 (Odyssey Blue) 2001 'Y' Laguna II 1.8 16v 'Expressionale' Hatch (BG0B F4P-770)
Azurael is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Azurael For This Useful Post:
simoncollins (13th December 2011)
Old 13th December 2011   #3
simoncollins
simoncollins is
has no status.
Junior Member
Threadstarter
Thank you for the info
Yes I have had 3 Mk I's (2x original and 1x facelifted) and 2 MkII's (2x original and 1x facelifted)
Love em!
S
Old 21st April 2012   #4
Chillman
Chillman is
has no status.
Member
Well, I have an expert VW mechanic who reckons this is caused by a short in the heated driver's seat of my MII 1.9dCi Laguna 2003! When they put seats in they plug in connections and these work loose after manufacture. Thus lighting up fault. So disconnect car battery [ otherwide all sorts gets upset] and solder wires togther to prevent continuing fault. I will let you know if this works! Oh, my wife moves the seat further forward and guess what comes on! The air bag fault light. [It didn't help that she kept saying it was the seat belt light!]
Currently in Chillman's garage:
VW mechanic who is cool and honest!
Chillman is offline   Reply With Quote Quick reply to this message
Reply
Tags
air bag off, laguna, warning
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
