clio 2004 1.2 16v - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
clio 2004 1.2 16v
Engines
Reply
Thread Tools Display Modes
Old 22nd December 2011   #1
abcnik
abcnik is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
clio 2004 1.2 16v
hi i have a clio 1.2 16v in that will not start turns over but nothing, fault codes are df009 df022 df131 df134
had the same problem not long ago i had a broken wire in the loom from the ecu all wires seem to check out ok
Currently in abcnik's garage:
renault clio 2004
abcnik is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by abcnik
clio 2004 1.2 16v Engines Lio 3 4517 22nd December 2011 12:46 PM
Sponsored Links
Advertisement
Old 22nd December 2011   #2
Lio
Lio is
has no status.
Diamond member
Re: clio 2004 1.2 16v
hi does your dash immobiliser light go out/flicker when you crank the engine or does it stay solid red? and have you checked the loom that goes to the throttle body as these are also prone to wires breaking through?
Currently in Lio's garage:
Renault Master 2.2dci 51reg.& Renault Scenic 1.4 16v 2000 reg Renault Megane Coupe 1.6 16v 2001 Mitsubishi Pajero 2.5 td lwb 1993
Lio is offline   Reply With Quote Quick reply to this message
Old 23rd December 2011   #3
abcnik
abcnik is
has no status.
Junior Member
Threadstarter
hi you turn the ignition on the stop light signal and management light stays on and immobiliser light goes off
have got several codes 68572 60 66d df003 560 52 df216 just will not fire no spark at the plugs
renault clio 2004
Old 23rd December 2011   #4
Lio
Lio is
has no status.
Diamond member
hi abcnik,Ive worked on a couple of the clio 1.2 16v and non starting has always been down to the immobiliser/ecu or broken wires either going into the top of the ecu the loom at the rear of the engine and the wires in the multiplug at the accelerator pedal,I noticed the codes here are different to the ones you first listed, I cant really advise you of any of the code symptoms as yet but hopefully someone will be able to soon,is it a suitable code reader you are using?as I dont recognise any of them you said you had repaired a broken wire in the loom near the ecu,my money would be on this location being your problem ie,possibly more broken wires as I think if it had been an immobilser fault you would have had a solid red light on the dash. I will have a look and see if I can find any explanations for your fault codes meantime.
Reply
Tags
16v, 2004, clio
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
