espace the race - nose and smoke below fuse box/battery - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 11th January 2012   #1
Auntiebigbum
Auntiebigbum is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have a renault espace 2.2 dci the race 2002 plate. i have a bubbling noise occassionally by the fuse box/battery under the bonnet, some smoke and then a fan kicks in but the fan kicks in even after engine is off. It has happened three times now radomly with no pattern. As it doesnt happen very oftern ive never had anyone else about - until today when my friend also noticed it...but still no explanation. Ive tried today to get a manual but they dont do one. Is there a fan in this area and can anyone pls give me some advice what it could be. Dosnt help it doesnt happen very often. Many thanks
Currently in Auntiebigbum's garage:
Auntiebigbum is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Auntiebigbum
mountain range looking warning light Electronics chrisonajourney 8 1359 13th April 2012 11:32 AM
espace the race - nose and smoke below fuse... Engines Auntiebigbum 3 1138 11th January 2012 03:11 PM
Hi & can anyone pls help! Electronics pmregan 1 787 11th January 2012 02:59 PM
Sponsored Links
Advertisement
Old 11th January 2012   #2
mord
mord is
not a complete idiot, some parts got Leftbehind,...(in the UKraine)
Platinum member
mord's Avatar
Nominated 2 Times in 10 Posts
Nominated TOTW/F/M Award(s): 3
Re: espace the race - nose and smoke below fuse box/battery
hi
err, yeah, wtf? your right there is no Espace2 haynes manual ??? i checked on the haynes site...
you could always search online for MR300ESPACE4 and grab all the other Reno espace manuals out there. so you have something to fall back on for reference.
bubbling noise sounds like air in the cooling system, you might have a blown head gasket, but should keep a close eye on the level of the coolant topup bottle and see if the coolant changes colour(oil contamination.)
it is common for the older renos to have problems with the electronic fan Thermostat, which can either decide to switch completely off or on which will need to be replaced, the thermostat is located on the right side of the radiator (usually) about half way down the side. be carefull to keep an eye on the temperature guage, if it overheats then stop the car immediatly and sort it out (paperclip between the contacts of the fan thermostat connector, which will keep the fan running to keep it cool) if you dont then you risk a warped head and blown head gasket.
if you are having interiror heating issues then you need to bleed the cooling system (bleed valves on teh top of the pipe into the interior heater(thumb screw), on the left of the radiator at the top(plastic thumb screw with screw head), and on the front right of the engine block(metal bleed valve bolt.)
Currently in mord's garage:
The CreditCard Holes sooo DEEEEP NASA have put up warning signs about a black hole on the Driveway: update, the driveway and home have fallen in...
mord is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to mord For This Useful Post:
Auntiebigbum (11th January 2012)
Old 11th January 2012   #3
mr espace
mr espace is
turning into mr clio !!
Platinum member
mr espace's Avatar
Nominated 0 Times in 7 Posts
The noise is the auxiliary heater it comes on and heats the coolant up from cold starts it also brings a fan on
The heater is mounted bellow the battery
Currently in mr espace's garage:
espace escort cabriolet subaru legacy clios etc !!
mr espace is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to mr espace For This Useful Post:
Old 11th January 2012   #4
Auntiebigbum
Auntiebigbum is
has no status.
Junior Member
Threadstarter
thanks guys ill look into these. the head gasket was meant to be done on the car by its last owner. so hoping its not that and the water level is fine as i do keep a good check on this.
Reply
Tags
box or battery, espace, fuse, nose, race, smoke
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
