Causes for fault code DF 089 ? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 12th January 2012   #1
AidyMc1
AidyMc1 is
has no status.
Diamond member
AidyMc1's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My 2.0 dci115 trafic started to "miss" now and again which gradually got worse over 3-4 weeks. Had dash lights on but a new MAF cured that. But now it's a splutter up through the gears and it only drivable if you can get it into 6th & keep it around 60mph. Going to try main dealer for diagnosis next week but wondered had any of you guys had an idea of what the code meant and maybe possible causes for the spluttering, ie injector,faulty pump,no pressure in rail. Does anyone know if these vans have a pump in the tank also?
Aidy
Currently in AidyMc1's garage:
2007 2.0 115dci Trafic SL29, 1999 Toyota Corolla 1.3, 04` Toyota Avensis T4 D4D, 01` Avensis GS D4D
AidyMc1 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by AidyMc1
New 2014 Trafic engines...Are they in other... General Chat huwwatkins 5 1168 27th April 2014 09:08 AM
More Trafic problems Engines AidyMc1 2 874 28th July 2013 11:23 PM
07 trafic re-sets trip counter Electronics AidyMc1 0 560 20th April 2013 12:39 PM
115dci Trafic Stopped Engines AidyMc1 3 1210 19th April 2013 06:55 PM
What van should i buy Next ? Other makes VelSatisfied 6 2834 13th June 2012 10:39 AM
Sponsored Links
Advertisement
Old 12th January 2012   #2
bobbydog
bobbydog is
a professional layabout
Platinum member
bobbydog's Avatar
Nominated 0 Times in 3 Posts
Nominated TOTW/F/M Award(s): 2
Re: Causes for fault code DF 089 ?
On vehicles with Bosch injection systems code DF 089 = ''over/under voltage in the capacitor controlling the injectors''
Renaults remedy sounds expensive, replacing the vehicles computer etc
Currently in bobbydog's garage:
MkI Megane 1.4 16v
bobbydog is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to bobbydog For This Useful Post:
AidyMc1 (12th January 2012)
Old 12th January 2012   #3
AidyMc1
AidyMc1 is
has no status.
Diamond member
Threadstarter
AidyMc1's Avatar
Smile Re: Causes for fault code DF 089 ?
Hi Bobbydog, thanks for that. Would it be possible that the problem maybe caused by wire exposed by worn covering or water damage to tops of injectors? I know they are prone to water getting in though the bonnet vent/scuttle panel and dripping down onto the top of the engine? Mine was quite wet when i took of the plastic covering. I took the sponge out from underneath it as to my mind it was just preventing the water evaporating with the heat of the engine.
Thanks for your reply,trying to cover all angles before i start shelling out for any parts or labour. Much appreciated http://www.renaultforums.co.uk/images/icons/icon7.gif
Old 12th January 2012   #4
bobbydog
bobbydog is
Platinum member
bobbydog's Avatar
TBH i ain't got a clue to its cause .
I just looked up fault code DF089 and its meaning/remedy according to Renault.
Out of interest what code reader did you use?
Renault fault codes usually begin with DF so i'm presuming you used CLIP or a quality alternative.
MkI Megane 1.4 16v
Old 12th January 2012   #5
AidyMc1
AidyMc1 is
has no status.
Diamond member
Threadstarter
AidyMc1's Avatar
Mechanic & i brought van up the road to a(old school) guy who does bit of Auto electrical ie Alternators,Reconditioning etc. That was the only DF code he read out. I would have liked to have seen what it said for myself but didnt want to look like a know-it-all. It was About the size of a laptop with a touch-screen in the missle about 6x8 inches. My Mechanic did try a "Sealey" Machine(hand held) that threw up DF050 & 056 but we were oblivious to what they were. I got some Reference stuff in PDF format which looked like renault documentation. but someone said that different models meant different meanings for the codes.@
Reply
Tags
089, code, fault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
