Laguna III 2.0 150Dci - Where's the Oil Filter ? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 22nd January 2012   #1
derek900r
derek900r is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I know that this sounds a stupid but I wanted to do an oil and filter change on my Laguna and can't find the oil filter. I've gone to the trouble of identifying the right oil (RN0720 because of the FAP) but when under the car doing a recce I couldn't locate the filter.
There is a black plastic cover/cap under a seperate housing at the front of the engine just in front of the sump that looks like it unscrews but the pipework going into it looks like coolant pipes.
This is a 2008 Laguna 3 tourer with the 2 litre 150Dci engine in it with the particulate filter in the exhaust system.
Can anyone help of even send a photo ?
On another note, I get a very brief puff of light grey smoke on a cold startup only. Is that normal ? I'm keeping the oil level at about 1/2 wat on the dipstick.
Regards,
Derek
Currently in derek900r's garage:
2008 Renault Laguna III Estate 2.0 Dynamique S DCi 150
derek900r is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by derek900r
Laguna 3 2.0dci puffs smoke on startup Engines Turbotone 4 2111 23rd February 2012 07:25 PM
Laguna III 2.0 150Dci - Where's the Oil Filter ? Engines derek900r 2 3174 22nd January 2012 10:05 PM
New member here with an '08 Laguna Welcome to RenaultForums derek900r 5 1431 9th August 2011 09:51 PM
Sponsored Links
Advertisement
Old 27th January 2012   #2
Herr Doktor
Herr Doktor is
has no status.
Junior Member
Nominated 0 Times in 1 Post
Re: Laguna III 2.0 150Dci - Where's the Oil Filter ?
I just bought a Laguna Sports Tourer 2.0 dCi FAP 150 2010 and need to change the motor oil soon. I bought oil and the oil filter, but have not strated to look for the filter yet. The filter is a "open" one - not in a tin cup. There must be some cover to open where the filter is inside.
Currently in Herr Doktor's garage:
Renault Laguna Break 2.0 dci fap 2010 AT
Herr Doktor is offline   Reply With Quote Quick reply to this message
Old 29th January 2012   #3
derek900r
derek900r is
has no status.
Junior Member
Threadstarter
Hi, I had the same problem but it all turned out to be a lot easier than I thought it would be.
Once the undertray was removed, not easy when you don't have the car up on ramps, the sump drain plug is towards the back of the black steel engine sump cover. You will need an 8mm square plug driver tool to remove it. Remember that you are draining about 7 litres of oil so a couple of bowls may be needed to catch all of the oil.
A copper washer will be needed to reseal the plug.
The filter is inside the black plastic housing that is in front of the engine, just in front of the black sump cover. Unscrew this and the filter comes out with it (remember that more oil will also drain out from there).
The 'O' ring that seals the black plastic cover into the housing should be replaced (mine came with the filter).
It's all very easy. The most difficult bit was finding a suipplier if the 5W-30 oil that was compliant with the RN0720 specification.
I hope that this helps.
Derek
The Following 2 Users Say Thank You to derek900r For This Useful Post:
Dinnie (22nd May 2014), Rymkykut (14th June 2014)
Reply
Tags
150dci, filter, iii, laguna, oil
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
