Rear lights fault not bulb! - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 19th February 2012   #1
Exocet
Exocet is
hating French cars
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi all!
02 reg espace 2.2cdi went in for Mot and failed on
1. lower suspension ball joint, done, bugger to do!
2. CV gaiter, obviously opposite side to ball joint, done, bugger to do!
3. 2 new tyres, easy, someone else did it!
4. Rear brake pads, not too bad, what is the correct way of opening up the caliper so that new pads fit!
And finally stop light very dim and indicator comes on too! I need help, fuses and bulbs all ok so where do i go now! manual does not tell me where relay is. If i disconnect the rear light unit it still happens.
Please help, electrics not my strong point!
Currently in Exocet's garage:
Espace 2.2dc1 2002, TVR Chimaera
Exocet is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Exocet
Rear lights fault not bulb! Electronics Mikeyjp 2 839 19th February 2012 12:34 PM
self leveling? lights Electronics dejan72 2 598 15th November 2011 08:23 PM
temperature sensor Electronics 1 655 3rd July 2011 04:56 PM
2.2dci AFM Engines Leama 1 707 10th June 2011 04:43 PM
Espace 2.2dci 2002 Engines Exocet 11 2037 4th June 2011 09:51 PM
Sponsored Links
Advertisement
Old 19th February 2012   #2
GamithUK
GamithUK is
sometimes on RF
Diamond member
Re: Rear lights fault not bulb!
4)- with one of these, having used one for the first time just a couple of months ago they do make the process a lot easier.
As for the dim bulb - do you have a towbar fitted? if so could the brake line be earthing thus reducing the current available?
If not then I would look for a bad earth. One test you can try is to connect a multi-meter to the brake line and see what volts are being passed (should be 12v obviously) and if attaching the return side to the chassis makes a difference.
ttfn
Currently in GamithUK's garage:
2002 Renault Scenic 1.6 petrol Dynamique Auto
GamithUK is offline   Reply With Quote Quick reply to this message
Old 19th February 2012   #3
Mikeyjp
Mikeyjp is
moo
Platinum member
Mikeyjp's Avatar
rear lights, is going to be faulty/corroded/loose earth or connection
Currently in Mikeyjp's garage:
Clio 182 Trophy
Mikeyjp is offline   Reply With Quote Quick reply to this message
Reply
Tags
bulb, fault, lights, rear
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
