espace 2.2 dci - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
espace 2.2 dci
Engines
Reply
Thread Tools Display Modes
Old 8th March 2012   #1
kossack
kossack is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
espace 2.2 dci
Hi all first post so plese be kind
I have an espace 2.2 dci and most mornings it starts with the eml light on but when i drive a mile up the road and switch it all off and start it again the light goes off but comes back on after a bit.
But the funny thing is when the light comes on it has a lot more power??
and it has got i bit of a mis fire on tickover.
i havent looked at any thing yet but will be next week so any help would be a big help thanks.
Currently in kossack's garage:
2005 grand scenic 1.6vvt dyn
kossack is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by kossack
Grand scenic 1.6vvt Cars YOY 5 3527 29th June 2012 08:16 AM
espace auxiliary heater Heating & cooling plagu 2 1432 3rd May 2012 05:16 PM
espace 2.2 dci Engines mr espace 3 812 8th March 2012 09:13 PM
Sponsored Links
Advertisement
Old 9th March 2012   #2
Disgusted
Disgusted is
has no status.
Diamond member
Disgusted's Avatar
Nominated 0 Times in 1 Post
Re: espace 2.2 dci
The reason for the increase in power is probably that the engine management system is detecting the problem and then ignoring or disabling the faulty component, restoring normal performance.
The best way forward is to start by having the fault codes read by a good independent or dealer, and then carry out further tests to find the exact cause of the problem.
Regarding the slight misfire, the best starting point is a relative compression test. If that is ok you're probably looking at an injector or software fault.
Currently in Disgusted's garage:
Renault Kangoo 1.5 dCi 70PS, LDV Sherpa 2.0 VTdi 140PS, Vauxhall Vivaro 2.0 CDTI 115PS.
Disgusted is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Disgusted For This Useful Post:
kossack (9th March 2012)
Old 9th March 2012   #3
kossack
kossack is
has no status.
Junior Member
Threadstarter
Re: espace 2.2 dci
hi thanks for the reply i will see if i can get it pluged in next week and i will post back with the results
thanks again
Old 9th March 2012   #4
mr espace
mr espace is
turning into mr clio !!
Platinum member
mr espace's Avatar
Nominated 0 Times in 7 Posts
Re: espace 2.2 dci
Hi you may have a faulty airflow meter this tends to cause similar symptoms
Could also be injectors leaking internally sending too much fuel back to the pump
Could also be egr clogged
A said get it on a computer but get a print of any codes and what the computer says then clear them and see what codes come back
Currently in mr espace's garage:
espace escort cabriolet subaru legacy clios etc !!
mr espace is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to mr espace For This Useful Post:
Reply
Tags
dci, espace
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
