Scenic Megane intermittent starting problem - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 15th March 2012   #1
Michael Ryles
Michael Ryles is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi, I currently have a Scenic Megane 1.6 petrol 54 reg with a Intermittent starting problem.
Sometimes it starts first time then cuts out. And may take 2-3 attempts to get it to run normally. Other times 1st time OK no problems.
Recently it has brought on a message on the instrument panel, service and check emission's. The diagnostic cleared the problem for a few day and now the problem was back. The message flagged up top up AIR CON??
The car since has cut out at junctions as well till it is warm.
The garage has said it could be the ECU, as I was also having problems with my column switch for the headlamps dip to main beam and fog lights not working, although that is now OK its seems.
Could it be the sensor in the top of the engine?
Or something else.
Any advise please.
Mick
Currently in Michael Ryles's garage:
Renault Scenic megane 1.6
Michael Ryles is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Michael Ryles
Intermittent electrical problems Engines Michael Ryles 0 687 19th March 2012 10:17 AM
Scenic Megane intermittent starting problem Engines Michael Ryles 2 1744 15th March 2012 01:32 PM
Sponsored Links
Advertisement
Old 16th March 2012   #2
Haree
Haree is
has no status.
Diamond member
Nominated 0 Times in 2 Posts
Re: Scenic Megane intermittent starting problem
Hi Mick,
as your engine in your Scenic is the 1.6 16v VVT K4M engine do you get a rattle like noise on start up. If yes likely to be a faulty dephaser pulley and will cause poor running and difficulty starting from cold. Could also be the throttle body housing needs cleaning with carb cleaner.
Harry.
Currently in Haree's garage:
I don't have a garage just a driveway. The Modus 1.6 16v VVT Dynamique Auto is my Grandparents car which I also drive.
Haree is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Haree For This Useful Post:
Michael Ryles (27th March 2012)
Old 16th March 2012   #3
Michael Ryles
Michael Ryles is
has no status.
Junior Member
Threadstarter
It is a VVT I believe but I do not have the symptoms you describe. It is just as I mentioned. An intermittent stating problem but the diagnostics don't seem to be able to pin point it yet. Will see later.
Mick
Reply
Tags
intermittent, megane, problem, scenic, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
