Turbo Boost Sensor 1.9 DCi (130) 4 wires - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 16th March 2012   #1
Smidsy
Smidsy is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hello,
I have a check injection warning light and the error code DF004 "Turbo Boost Pressure Sensor" which only lights up when engine idling or not running.
This seems to indicate that the low pressure readings are wrong.
However, this is a FOUR wire sensor, not the usual 3 wires I find on here. Can anyone tell me what the readings should be on this sensor and what each wire does?
Thanks,
Simon.
Currently in Smidsy's garage:
Renault 1.9 Dci (130) Estate
Smidsy is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Smidsy
Turbo Boost Sensor 1.9 DCi (130) 4 wires Electronics Andy Anch LCC 3 5083 16th March 2012 09:37 AM
Sponsored Links
Advertisement
Old 19th March 2012   #2
Smidsy
Smidsy is
has no status.
Junior Member
Threadstarter
Re: Turbo Boost Sensor 1.9 DCi (130) 4 wires
Aha !
I found that this sensor is the Bosch T-MAP sensor with the details here:
http://www.bosch.com.au/content/language1/html/4596.htm
Definitely not a serviceable item !
Simon.
Old 19th March 2012   #3
Smidsy
Smidsy is
has no status.
Junior Member
Threadstarter
Also, following on from the above, I managed to get another TMAP sensor from e-Bay for a lot less than the £75 I was quoted and this seems to have doen the trick getting rid of the "Injection Fault" warning.
Time will tell however ...
Simon.
Old 24th January 2015   #4
Andy Anch LCC
Andy Anch LCC is
has no status.
Junior Member
Simon.
Did u get it sorted pal? My megane was displaying injection fault but changed UPC it now runs fine but is still saying check injection does it need ecu clearing or could other problem still need sorting
Currently in Andy Anch LCC's garage:
megane 2004 19 dci
Andy Anch LCC is offline   Reply With Quote Quick reply to this message
Reply
Tags
130, boost, dci, sensor, turbo, wires
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
