Where is the Fusebox!? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 26th March 2012   #1
chtheo
chtheo is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Firstly sorry if this is in the wrong place or anything, im new!
I couldnt find an answer to this in the other sections so i figured i would ask.
I dont pretend to know anything about cars, its somethign i want to learn about, but dont really have the time. Never the less, i bought a megane II.. i was impressed with it, that said i havent had it 6 months yet and already i have had a few problems.
The most recent of which is that the passenger window stopped opening. Due to my own apathy i figured "Hey! its still up i'll deal with it when i can be bothered" However, i got a kick in the pants this morning as while at the gym the window fell and now will not open.
The window stopped opening at about the same time as my passenger side headlight blew, so hopefully it isnt too much of a stretch to guess that this was possibly related?
I just figured checking the fuses might be a good place to start before i go and get fixed what could be a potentially expensive thing.
Any help would be greatly recieved!
Thanks,
EDIT - Found it! there was another post that showed up when i googled, turns out i wasnt using the correct words! Thanks all the same!
Currently in chtheo's garage:
Renault Megane II 1.5 DCI Dynamique 07
chtheo is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by chtheo
Removing Interior Panel Renault Megane II 3 Door Interiors hoochy 3 5756 26th March 2012 05:51 PM
Where is the Fusebox!? Electronics chtheo 5 4942 26th March 2012 09:11 AM
Sponsored Links
Advertisement
Old 26th March 2012   #2
TazzyK
TazzyK is
thinking I should have kept the Alfa
Platinum member
TazzyK's Avatar
Nominated 0 Times in 4 Posts
Nominated TOTW/F/M Award(s): 2
Re: Where is the Fusebox!?
Hi, glad you found the fuse box.
Not sure if the window and headlamp fuses would be the same or not, but the one for the headlamp (one each side) is in the fusebox under the bonnet - not the easiest to access but these few fuses can be got to by removing a cover and then using a long nose plier
Currently in TazzyK's garage:
Mercedes A140 Avantgarde (2001), Renault Megane 1.5 dCi 106 Expression (2005), Volkswagon Passat 2.0 TDi S (2006), Alfa Romeo 159 2.4 JTDm QTronic Lusso (2008)
TazzyK is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to TazzyK For This Useful Post:
chtheo (26th March 2012)
Old 26th March 2012   #3
chtheo
chtheo is
has no status.
Junior Member
Threadstarter
thanks for the reply.
I just ran out and opened the fuse box, from what the pictures say, they arent related at all! both fuses that control the windows are intact (as best i can see) and there seems to be no relation to the headlight. it just seemed a bit coincidental that they should both go wrong in such a small time-frame.
Looks like im going to have to remove the door panel - Awesome...
Old 26th March 2012   #4
TazzyK
TazzyK is
Platinum member
TazzyK's Avatar
Did the window jus drop by itself? It might be the motor cable snapped or something. You can get repair kits for them off ebay which is supposed to be cheaper than buying another motor, but whether they work or not I've no idea
Old 26th March 2012   #5
HeatherJ
HeatherJ is
HeatherJ's Avatar
Nominated 4 Times in 8 Posts
Yep best idea is to get the door panel off and have a look at the cables! Is the window now up or down?
Currently in HeatherJ's garage:
Peugeot 407 SW and a Honda Hornet 900cc
HeatherJ is offline   Reply With Quote Quick reply to this message
Reply
Tags
fusebox
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
