Megane Tourer 1.9 DCi Check Injection Fault - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 28th April 2012   #1
Natedawg8t6
Natedawg8t6 is
is like a singing 1 man band
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have recently bought a 2004 04 plate Megane Tourer 1.9 DCi 120 BHP.
It keeps coming up with the warning "CHECK INJECTION", but the car runs faultless. The warning normally appears when idling at traffic lights or stationary in traffic.
I plugged my PCMSCAN software into the car and its come up with the following fault codes:
P0100 : MASS or VOLUME AIR FLOW CIRCUIT MALFUNCTION
P0235 : TURBO BOOST SENSOR A CIRCUIT MALFUNCTION
P2226 : BAROMETRIC PRESSURE CIRCUIT.
As I said, the car runs faultless.
Any help would be greatly appreciated.
Thanks in advance
Currently in Natedawg8t6's garage:
Megane Tourer Privilege 1.9 DCi, Megane 2 1.5dci authentique
Natedawg8t6 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Natedawg8t6
1.9dci fault codes Tools & equipment Natedawg8t6 4 2973 10th December 2012 05:58 PM
1.9dci megane boost pressure solinoid Engines Natedawg8t6 10 2264 5th December 2012 09:16 AM
1.9dci megane NO POWER! Engines Natedawg8t6 7 1487 14th November 2012 10:21 AM
intercooler flush 1.9dci Engines SomersetScott 4 1684 4th November 2012 09:10 AM
peeing out oil 1.9 megane Engines madnoel10 5 1031 29th October 2012 08:07 PM
Sponsored Links
Advertisement
Old 28th April 2012   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Megane Tourer 1.9 DCi Check Injection Fault
The codes you have a generic and not Renault specific so they may be totally erroneous.
Have you checked the EGR valve - a very common fault on the Dci engines?
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 28th April 2012   #3
Natedawg8t6
Natedawg8t6 is
Member
Threadstarter
where is the EGR valve located and how do i clean it?
Old 28th April 2012   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
Try using the search facility on the forum. Search for EGR valve - there are numerous posts on the topic.
Honda Civic 1.4l
Old 15th May 2012   #5
Natedawg8t6
Natedawg8t6 is
Member
Threadstarter
well, last night i tried Wynnes EGR3 cleaner.
it seems to be running smoother at idle, not as lumpy. and the check injection warning isnt as regular. so it must have workd abit. should i try another tin of the spray cleaner or strip it down!
thanks
Reply
Tags
check, dci, fault, injection, megane, tourer
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
