Alternator Belt - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Alternator Belt
Engines
Reply
Thread Tools Display Modes
Old 6th May 2012   #1
eyeballroy
eyeballroy is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Alternator Belt
i need to replace the alternator belt on my clio 1.2 Vreg, does the timing belt need to be removed 1st.
Currently in eyeballroy's garage:
clio mkIII, Focus CC3 FJR 1300
eyeballroy is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by eyeballroy
Clio mkIII 1.2 Engines eyeballroy 2 525 2nd December 2012 04:24 PM
Alternator Belt Engines eyeballroy 6 1571 6th May 2012 08:29 PM
Sponsored Links
Advertisement
Old 6th May 2012   #2
Dan94
Dan94 is
has no status.
Junior Member
Re: Alternator Belt
as far as i know you dont need to as the alternator drivebelt is on the outside of the engine.
Currently in Dan94's garage:
1998 Renault Clio Grande 1.2 Petrol
Dan94 is offline   Reply With Quote Quick reply to this message
Old 7th May 2012   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Re: Alternator Belt
Hello and welcome to the forum.
No need to go anywhere near the timing belt.
You may have a twin belt arrangement on your car if you have power steering,if you do then I would definitely recommend replacing both belts together.
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 7th May 2012   #4
eyeballroy
eyeballroy is
has no status.
Junior Member
Threadstarter
Re: Alternator Belt
thanks all for the replies, but i looked a the engine and it looks like the alternator belt is nearer the engine with the timing belt on the outside (or am i being stupid!) anymore help and advice will be much appreciated, Roy
Old 7th May 2012   #5
Lagdti
Lagdti is
Veteran Member
Technical Supremo
Lagdti's Avatar
Re: Alternator Belt
The timing belt is in behind the plastic covers on the end of the engine,you are probably looking at the power steering belt and alternator belt (seperate belts for each).
Reply
Tags
alternator, belt
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
