2006 megane airbag and service light - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 7th May 2012   #1
wombler63
wombler63 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have a 2006 1.5 dci megane which has the airbag and service light on.
I bought the car with damage to front but fixed it, the drivers seatbelt pretensioner had gone off so i replaced it.
I then got the crash data cleared from the airbag module but the lights stay on. Now when i read the fault codes i get df210 seatbelt buckle, pretensiometers circuit open fault.
Has anyone come across this fault before?
Currently in wombler63's garage:
2006 megane
wombler63 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by wombler63
2006 megane airbag and service light Electronics fhurzel 3 5217 7th May 2012 07:28 PM
Sponsored Links
Advertisement
Old 7th May 2012   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: 2006 megane airbag and service light
Will the code not clear from the ECU.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 9th May 2012   #3
marinosg
marinosg is
has no status.
Edit
Posts: n/a
Check the wiring under the seat. Spray also with some contact clean at the connections. This worked for me when I had the same problem
Old 10th May 2012   #4
fhurzel
fhurzel is
has no status.
Junior Member
Check if your pretensioners are damaged, replace them or just disconnect the wire going to the pretensioners (damaged ones) and link it with a 2 ohm resistor. If service light does not go off it might be damage ECU airbag unit.
Currently in fhurzel's garage:
Megane 3
fhurzel is offline   Reply With Quote Quick reply to this message
Reply
Tags
2006, airbag, light, megane, service
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
