Renault trafic wont start, Help! - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 10th June 2012   #1
ACVken
ACVken is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi all, I bought a 2002 renault trafic 1.9 dci sl29 with 72k on the clock a few weeks back. Everythings been fine up untill this morning. I parked the van up last night but when i came back to it today i noticed that the glow plug light isnt lighting up at all and the van wont start. It turns over, just wont fire up. Does anyone have any ideas what the fault could be. Gratefull for any help, thanks in advance.
Currently in ACVken's garage:
trafic
ACVken is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by ACVken
trafic indicators not working Electronics ACVken 4 3835 7th July 2012 12:33 PM
clucking/knocking noise over bumps Wheels & tyres mah14681 3 2442 15th June 2012 01:23 PM
Renault trafic wont start, Help! Engines ACVken 15 13172 10th June 2012 01:59 PM
Sponsored Links
Advertisement
Old 10th June 2012   #2
mr espace
mr espace is
turning into mr clio !!
Platinum member
mr espace's Avatar
Nominated 0 Times in 7 Posts
Re: Renault trafic wont start, Help!
Glow plugs have a main fuse under the bonnet check thats not blown its a big 40 or 70 amp type fuse
Currently in mr espace's garage:
espace escort cabriolet subaru legacy clios etc !!
mr espace is offline   Reply With Quote Quick reply to this message
Old 10th June 2012   #3
ACVken
ACVken is
has no status.
Junior Member
Threadstarter
Quote:
cheers for reply, just checked the fuses, they all seem fine. Noticed a slight buzzing noise coming from the drivers side of the engine bay when the ignition is switched on. Not sure if this will be related.
trafic
Old 10th June 2012   #4
mr espace
mr espace is
Platinum member
mr espace's Avatar
Buzzing is the fuel pressure regulator thats nothing to worry about
Im not sure if the glowplugs are a seperate circuit on your van or if they get power along with other things i recon they get powered from something else hence no glow no start there is a main power relay somewhere beside the fuses
Sorry im more used to espaces and lagunas
Old 10th June 2012   #5
ACVken
ACVken is
has no status.
Junior Member
Threadstarter
No probs, cheers for your help mate
Theres quite a few relays in there, would it be worth taking the relays out and cleaning up the terminals
Ive noticed that the glow plug light briefly comes on when turning the engine, only for a split second tho.
I had a transit before this and not once did it not start in 2 years of owning
trafic
Reply
Tags
renault, start, trafic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
