HELP! Megane 225 hub - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Brakes/Hubs
Notices
Brakes/Hubs Brakes, Hubs, and etc
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Brakes/Hubs
Reply
Thread Tools Display Modes
Old 12th June 2012   #1
leehanslip
leehanslip is
having a steering issue!
Member
leehanslip's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Can anyone tell me if the top & bottom bearings in the front wheel hubs can be replaced? Or is it a case of complete new hub?!!
Cheers
Currently in leehanslip's garage:
Renaultsport Megane 225 Trophy '55 plate
leehanslip is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by leehanslip
HELP! Megane 225 hub Brakes/Hubs leehanslip 5 5770 12th June 2012 12:58 PM
Megane 225 CV Joints? Brakes/Hubs leehanslip 4 2587 9th June 2012 01:37 PM
megane 225 drive shaft outer boot replacement Transmissions leehanslip 5 4023 8th June 2012 11:22 PM
Bilstein Shocks - Recommended or not? Handling & braking leehanslip 0 1096 28th September 2011 09:46 PM
Fuel Flap Retainer Clips Bodywork leehanslip 0 763 23rd September 2011 10:25 AM
Sponsored Links
Advertisement
Old 13th June 2012   #2
leehanslip
leehanslip is
Member
Threadstarter
leehanslip's Avatar
Re: HELP! Megane 225 hub
Or.....
Another idea someone who's had this problem may have tried, can you strip the hub down completely and give it the best clean possible in order to free up the seizing bearings?
[Yes I could try it and find out, but would be nice to know if I'm wasting my time before hand ]
Surely with how common a problem this seems to be, someone would have experienced & solved the problem by now?
Old 13th June 2012   #3
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Are you referring to the hub (wheel) bearing or the strut bearing??
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 13th June 2012   #4
leehanslip
leehanslip is
Member
Threadstarter
leehanslip's Avatar
Quote:
I believe it's name is the 'hub carrier bearing', it's located at the bottom of the hub [as it is on the car] and allows the hub to swivel in order for the wheel to turn. There is also a bearing at the top of the hub, but as it is the lower one that's carrying the weight it seems to be this one seizing up.
The garage had it all stripped down the other day so they could fit 2 new drive shaft boots, and that's when the problem became conclusive. They advised 2 new carrier hubs and labour would be over £900 all in. That's money I wouldn't pay even if I had it, which I don't! lol
Old 13th June 2012   #5
madnoel10
madnoel10 is
has no status.
Technical Supremo
As far as I know the bearings are not available as separate components as they are a press or freeze fit.
Try a google search for Megane Sport - I have seen this problem mentioned in other Renault forums - you may find a solution.
One of the joys of owning a spory car eh!
Honda Civic 1.4l
Reply
Tags
225, hub, megane
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
