renault traffic starting problems - Page 5 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 24th June 2012   #21
donald68
donald68 is
has no status.
Diamond member
Nominated 0 Times in 1 Post
TOTW/F/M Award(s): 0
Re: renault traffic starting problems
Me too... I was just wondering why bernie thought it might be an earth strap after you said the cranking speed was OK.
Currently in donald68's garage:
Grand Espace 3 16v Auto, Scenic Dti Auto & Fluence ZE
donald68 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 24th June 2012   #22
donald68
donald68 is
has no status.
Diamond member
Excuse this very basic question, but when was the fuel filter last serviced?
Old 24th June 2012   #23
derrick013
derrick013 is
just help me guys
Diamond member
Threadstarter
Nominated 0 Times in 0 Posts
Quote:
just bought van so as for the guy telling me that it was fully serviced i wouldnt believe a word of it because he knew there was a problem with it
SO NOT SURE WHEN IT WAS LAST CHANGED
Currently in derrick013's garage:
2006 trafic 1.9 dci 100 2008 1.5 DCI MODUS renault kangoo 1.5 dci mpv KANGOO SL17 DCI
derrick013 is offline   Reply With Quote Quick reply to this message
Old 24th June 2012   #24
SomersetScott
SomersetScott is
nuts..
SomersetScott's Avatar
Well if you're convinced its feul starvation its either something tripping ECU or something mechanically wrong.
Have you tried all the generic fixes to do with bad starts? Clean EGR, change TDC sensor. Etc etc?
Leaking feul - if large amount wouldn't let car start and car would cut out. Small amount would cause hesitation especially pulling away, perhaps cut out. All these syptoms would be 'spluttery' rather than 'crisp' problems. So if they are as they sound - clear/crisp cut offs it points to ECU surely?
Perhaps as its such a strange problem its worth having a proper diagnostic ran on it? - could spend a lot of time and cash trying to fix something that could have been trivial.. personal opinion
__________________
Currently in SomersetScott's garage:
Mégane 1.5dCi Rush (Mk 2, 2005), Clio 1.5dCi (Mk 2, 2005) & Rover 100 K-series 1.1L (1996)
SomersetScott is offline   Reply With Quote Quick reply to this message
Old 24th June 2012   #25
derrick013
derrick013 is
just help me guys
Diamond member
Threadstarter
Quote:
Originally Posted by somersetscott View Post
well if you're convinced its feul starvation its either something tripping ecu or something mechanically wrong.
Have you tried all the generic fixes to do with bad starts? Clean egr, change tdc sensor. Etc etc?
Leaking feul - if large amount wouldn't let car start and car would cut out. Small amount would cause hesitation especially pulling away, perhaps cut out. All these syptoms would be 'spluttery' rather than 'crisp' problems. So if they are as they sound - clear/crisp cut offs it points to ecu surely?
Perhaps as its such a strange problem its worth having a proper diagnostic ran on it? - could spend a lot of time and cash trying to fix something that could have been trivial.. Personal opinion
cleaned out egr valve today wasnt that bad no fuel leaks havnt tried cam sensor or crank sensor other than checking connection van drives 100% once going but if you rev it out threw gears it seems to hold back once to get to 4000rpm its like a cut off point limiter rather than that it drives fine
ALSO HAD A DIAGNOSTIC DONE AND COMPUTER WAS SAYING O2 SENSOR AND THERE IS NO O2 SENSOR ON THE VAN BUT THIS IS PROBABLY DOWN TO IT NOT BEING DONE BY RENAULT SOFTWARE
Reply
Tags
problems, renault, starting, traffic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
