Code P2002 Laguna 3 gt - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 8th July 2012   #1
Gary bax
Gary bax is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Further to my previous post I have now cleaned the erg valve which was heavily sooted, however the check anti pollution message and check fuel. Injection warning light still comes on. The ecu reads 2 codes 1 P2002, and the other a pending code wich I assume is the fuel injection warning as this does not register the code error and re setts itself with the ignition.
Has any one experienced the p 2002 error, I have read that it may be the cat, any advice appreciated thanks Gary
Currently in Gary bax's garage:
Laguna 3gt180
Gary bax is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Gary bax
Koleos Air Con problem Heating & cooling Gary bax 2 975 17th July 2013 08:09 PM
Code P2002 Laguna 3 gt Electronics Gary bax 15 6059 8th July 2012 04:29 PM
Laguna 3 GT 180 problems Engines Gary bax 0 718 5th July 2012 05:36 PM
Sponsored Links
Advertisement
Old 8th July 2012   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Code P2002 Laguna 3 gt
Firstly your code seems to be generic and possibly erroneous. Renault use a different protocol in their ECU's so not all code readers are compatible. A search of the internet seems to indicate the code relates to a blocked diesel particulate filter (DPF or FAP).
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 8th July 2012   #3
Gary bax
Gary bax is
has no status.
Junior Member
Threadstarter
Thanks, that's the bit I don't understand I have had the Dpf filter removed?
Laguna 3gt180
Old 8th July 2012   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
Has the ECU been remapped to suit?
Honda Civic 1.4l
Old 8th July 2012   #5
Gary bax
Gary bax is
has no status.
Junior Member
Threadstarter
Yes it has,
do you know if there should be a pressure difference at the Dpf pressure sensor even though it has been remapped, the p2002 code I have seen is particulate trap efficiency below threshold and I wondering if the pressure sensor is the problem, or the fact that there is now equalpressure due to the filter being
removed
Laguna 3gt180
Reply
Tags
code, laguna, p2002
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
