Scenic 1.9 dCi Starting problem - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 18th July 2012   #1
big51me
big51me is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My X reg scenic has developed a starting problem that resembvles the same symptoms as if the TDC sensor is faulty however my mate took this off and it was clean and was only replaced about 8 months ago.
He then sprayed some easy start in whilst I turned the engine over and everything fired ok but still wouldnt run. We had to then give up as it was getting dark last night and in frustration I slammed the bonnet. I tried once more and the engine fired up and ran no problem. This morning it fired briefly and then nothing and so i slammed the bonnet closed again and it fired on first turn of the key!
Once started it runs fine but on occasion it leaves 2 red lights on the dash - battery and something else. When I rev the engine they go out and stay out so not sure what that is. We have tested the battery etc and its all fine and we are getting 13+ volts.
Please help as I am at my wits end and need the car for work every day.
Thanks in advance
Currently in big51me's garage:
2000 Megane Scenic 1.9dCi Sport Alize
big51me is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by big51me
Steering Rack help please!! Steering and Suspension madnoel10 3 853 28th September 2012 11:59 AM
Scenic 1.9 dCi Starting problem Engines rjk1188 4 3144 18th July 2012 10:37 AM
Sluggish from start 1.9 DCI Engines big51me 4 1182 15th February 2012 07:58 PM
Sponsored Links
Advertisement
Old 18th July 2012   #2
scrabolad
scrabolad is
has no status.
Member
Smile Re: Scenic 1.9 dCi Starting problem
Hi, have you had a diagnostic check carried out to identify any faults. It has been known for the tdc sensor wires to be faulty so much that when you buy a new one it comes with new connector and wires which you solder into wiring loom. Hope this is of help to you
Currently in scrabolad's garage:
Scenic 1.5 dci very sick car
scrabolad is offline   Reply With Quote Quick reply to this message
Old 18th July 2012   #3
big51me
big51me is
has no status.
Junior Member
Threadstarter
Well the sensor hasnt seemed to be a problem, i went out at lunchtime to start the car and it fired up fine. It may now go for a while without a glitch then suddenly it wont start again. The only thing I can say is the symptoms are the same as when that sensor was faulty. Is there anything else that it could be?
Old 23rd July 2012   #4
big51me
big51me is
has no status.
Junior Member
Threadstarter
Well after a few days of driving without a problem whilst driving downb a dual carriageway the orange light came on and the car lost all power. I turned the car off and on while rolling down the road and it fired up and I managed to limp home. I later went out again but it died again. After a while it restarted but again died on me. Whatever it is seems to be very random. The wires have not been replaced from the loom to TDC sensor so maybe thats what it is perhaps. CAn anyone think of anything else?
If I call the RAC will they be able to diagnose on the roadside?
Old 23rd July 2012   #5
rjk1188
rjk1188 is
has no status.
Diamond member
rjk1188's Avatar
Nominated 0 Times in 1 Post
rac should be able to plug in there diagnostics to read the fault codes
Currently in rjk1188's garage:
2005 jaguar x type 2.0d
rjk1188 is offline   Reply With Quote Quick reply to this message
Reply
Tags
dci, problem, scenic, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
