Renault Scenic 2.0 2001 vvt how to set the Timing - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 20th July 2012   #1
defender
defender is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
We have a Renault Scenic 2.0 2001 Engine striped and ready to re assemble, how do we set the VVT Timing ?.
Thanks Frank
Currently in defender's garage:
TD5 Defender
defender is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by defender
Renault Scenic 2.0 2001 vvt how to set the Timing Engines S80 4 3252 20th July 2012 10:45 AM
Sponsored Links
Advertisement
Old 20th July 2012   #2
bugsb
bugsb is
at home
Platinum member
bugsb's Avatar
Nominated 14 Times in 11 Posts
Nominated TOTW/F/M Award(s): 2
Re: Renault Scenic 2.0 2001 vvt how to set the Timing
for the 16v you will need a timing kit /tools around £30 on ebay
you can make them and there are threads around showing you how like the cam locking tool and size bolt needed to lock the crankshaft
Ron
Currently in bugsb's garage:
MGF 1.8 1999/honda hrv 2002
bugsb is online now   Reply With Quote Quick reply to this message
Old 20th July 2012   #3
defender
defender is
has no status.
Junior Member
Threadstarter
cheers, we have all of this and the tool kit, its the setting of the actual Variable Valve unit on the timing belt end of the cam.
TD5 Defender
Old 20th July 2012   #4
bugsb
bugsb is
at home
Platinum member
bugsb's Avatar
the haynes bible has all of this in it along with everything else needed info wise cant remember if there is a thread on this
but another member will be along with the info you need
Ron
Old 20th July 2012   #5
S80
S80 is
has no status.
Diamond member
Nominated 0 Times in 1 Post
It's just a case of ensuring that the 'dephaser' pulley is positioned fully in one diection relative to the cam when the belt is fitted. Unfortunately, I can't remember whether it's 'fully left' or 'fully right'
Currently in S80's garage:
Megane I Phase 2 1.8 5dr
S80 is offline   Reply With Quote Quick reply to this message
Reply
Tags
renault, scenic, set, timing, vvt
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
