Kangoo 1.5Dci - Starting Issue * FIXED * - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Engines
Notices
Engines Engines and other oily matters
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Use the drop-down below to display RenaultForums in the language of your choice.
Engines
Reply
Thread Tools Display Modes
Old 19th November 2015   #1
NoKango
NoKango is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hello all,
I have a 2006 Kangoo 1.5DCi van which has failed to start for me for the past week.
What I have observed:
1. Immobiliser light flashes correctly without key.
2. Immobiliser light steady red with key inserted at position 2
3. With key at position 2, no glow plug/engine light
4. Cranks, but doesn't fire.
5. OBD unit will not connect to ECU.
6. Glow plugs operate correctly, with correct voltages
7. Fuel flows without air bubbles.
What I have tried:
1. Replace Glow Plug Relay/Control Module with brand new dealer part.
2. Replace main engine relay with brand new dealer part.
3. Replaced the glow plugs with 4 x brand new Beru
None of these has fixed the issue.
Intermittantly, the glow plug light will come on the dashboard (maybe once per day if I'm lucky) When it does start it sounds sweet, just as it should, but when power applied (as in trying to move off), the engine stalls, no glow light, and refuses to restart.
My experience with fixing cars is somewhere below the 'Virgin' level, so 'Monkey See, Monkey Do' replies please, any advice welcomed!
Lastly - Thank You in advance!
Currently in NoKango's garage:
2006 Kangoo Van 1.5Dci
NoKango is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by NoKango
Thread Forum Last Poster Replies Views Last Post
Kangoo 1.5Dci - Starting Issue * FIXED * Engines NoKango 10 515 19th November 2015 04:15 PM
Sponsored Links
Advertisement
Old 19th November 2015   #2
ours2012
ours2012 is
Stus son Rory
Platinum member
ours2012's Avatar
Nominated 12 Times in 11 Posts
Nominated TOTW/F/M Award(s): 6
Re: Kangoo 1.5Dci - Starting Issue
Have you checked the relays in the engine compartment ,,
Currently in ours2012's garage:
bmw 318 fiat doblo corsa mondeo (megane we dont talk about)mazda 6
ours2012 is offline   Reply With Quote Quick reply to this message
Old 19th November 2015   #3
NoKango
NoKango is
has no status.
Junior Member
Threadstarter
Yes all relays have been replaced regardless...
Old 19th November 2015   #4
Coventry
Coventry is
has no status.
Diamond member
Coventry's Avatar
Nominated 8 Times in 6 Posts
Nominated TOTW/F/M Award(s): 4
Can someone confirm whether the immobiliser light is supposed to remain steady-red with the key in position II first (I don't know)?
After someone has answered that, OP, have a read through this:
http://www.renaultforums.co.uk/showthread.php?t=412226
Currently in Coventry's garage:
2003 Clio dCi 65
Coventry is offline   Reply With Quote Quick reply to this message
Old 19th November 2015   #5
NoKango
NoKango is
has no status.
Junior Member
Threadstarter
Thanks, I have already read through that - as I have most every other thread regarding 1.5DCi starting issues.
Usually, the Immo light flashes until the key is in position 2, then will extinguish as the engine starts.
However, it remains solid red throughout cranking, and will therefore not fire.
I have tried it with both keys, same result.
One key is a brand new dealer part costing plenty pennies, but the dealers have had all they are having out of me now.
I can't for the life of me figure out why the glow plug light is intermittent, when it does flash up, the van will start and sound sweet. Stopping and trying to restart is futile... it just won't do it.
Also when the light does flash up, I can connect my OBD reader to the socket, and it will connect to the ECU.
The only code I have had is P0670 - Glow Plug Control Module Circuit Open - hence my changing the plugs and the relay with new parts.
Once I clear the code, the engine will start fine. On stopping, and rescanning, P0670 rears its' ugly head again.
Reply
Tags
15dci, fixed, issue, kangoo, starting
Quick Reply
Message:
Options
Post Icons
You may choose an icon for your message from the following list:
Register Now
In order to be able to post messages on the Renault Forums :: Independent Renault forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
What's current in your garage?
Please share a bit of information about what you drive. For example: 2004 Renault Laguna II 1.9dCi. This is in addition to the model field above. This will appear in your signature so that our members know what you drive
Where are you?
What model do you own?
You must fill this field in
We'd like to better understand our user demographic. We'd be grateful if you could choose the model you currently drive from the list below. If you have more than one car, please choose the model representing your main car. This is for demographic purposes
Where in the country are you?
This field allows us to determine roughly where our members are. We have some region specific activites coming up in the future
What's your team?
Who do you support? Setting this option will show your allegiance in your posts. Leave this field blank by all means
Panic Button - On/Off Switch
The Panic Button is an icon that resides at bottom right hand corner of every post. If your Boss (or maybe the Wife) turns up, clicking the Panic icon immediately sends you to another web site of your choice.
Select the appropriate button to turn this feature On or Off.
Panic Button - URL Jump
This is the URL (web address) of the web site that is jumped to when you click on the Panic Button. Make sure you use the full address including the http://. For example:
http://www.Google.co.uk
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
Copyright © 2005-2015 RenaultForums
