Engine runaway but still starts and runs but with white smoke - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 7th September 2012   #1
Demascus
Demascus is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Engine runaway but still starts and runs but with white smoke
Hi peeps this is my first post hope you can help me. I have been given an espace 02 plate 2.2dci as I took it for a test drive before buy it and this is what happened test drove it for aprox 45-60 min took it home then decided to take it to a friend of mine to put it on a ramp and look underneath for me but never got there I was driving for about 2 mins then the stop light came on so I stopped let everything calm down started it again and was fine for about 2 min then done it again so I went to pull over switched the ignition of but the car kept running and then went full revs for a few seconds I then dumped the clutch in a high gear and managed to stop the engine but did poor out a huge amount of white smoke and left an oily deposit at the rear of the car once every thing had calmed down I dipped the oil stick and it was aprox 3 inches above the full mark (wtf) I thought, so anyway managed to get it home by towing it I've since started the car and it idles ok dipped the stick again and it's 1 inch above the full mark but it still smokes and I think it will for a bit but Iam going to drop the oil and refresh it with filters and bits just wondered if anyone could give me some advice on why,how, and what can I do to test it to see what has gone on it because at the mo the only thing I can think is over filed with oil from last owner might I add not got, any avice will be much apretiated many thanks in advance Matt.
Currently in Demascus's garage:
Renault espace the race 2.2dci 2002
Demascus is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Demascus
Engine runaway but still starts and runs but with... Engines madnoel10 6 1322 7th September 2012 12:20 AM
Sponsored Links
Advertisement
Old 7th September 2012   #2
silverdave43
silverdave43 is
has no status.
Member
Unhappy Re: Engine runaway but still starts and runs but with white smoke
Blocked particle filter causing unburnt fuel to biuld up in the sump, probably brought about by vehicle being used on short school runs and not allowing engine to reach operating temperature. The "Daily Telegraph" motoring Journalist has covered this --see website "honestjohn"----Fiat suffer from same problem
Currently in silverdave43's garage:
suzuki burgman 400, Yamaha XJ900 Skoda Fabia
silverdave43 is offline   Reply With Quote Quick reply to this message
Old 7th September 2012   #3
Alex3
Alex3 is
has no status.
Diamond member
Doubt that an 02 engine would have a DPF. But a build up of diesel in the sump has caused the high dipstick reading. Possibly a failed injector dumping excess fuel.
Alex3 is offline   Reply With Quote Quick reply to this message
Old 7th September 2012   #4
greenside
greenside is
has no status.
Edit
Posts: n/a
If you search on here, you'll find that Renault diesels don't like to be over-filled with oil (even a little bit). The result is usually as you've described here. You need to remove the excess oil and see how it goes.
Richard.
Old 7th September 2012   #5
VelSatisfied
VelSatisfied is
International, but his heart is always where the weather's nice.
S.M.A.R.T.(y) Pants
VelSatisfied's Avatar
Nominated 11 Times in 37 Posts
Nominated TOTW/F/M Award(s): 17
Hi Matt.
Just a thought here which you might want to check out - could the head gasket/engine block be cracked?
Oil will sit above coolant, which could explain the elevated level you've noticed.
It's easy enough to check the coolant for the presence of any oil.
Coolant also gives off white smoke.
HTH,
Paul
__________________
This job should never be complete - the day I think I've done it all, is the day I resign.
S.M.A.R.T. Technician
Currently in VelSatisfied's garage:
2005 FIAT Ducato 2.8JTD LWB Gran Volume, 2000 Kawasaki ZZR 1100 D7 'fullpower' in black + full GIVI & KAPPA luggage, 2007 MB R-Class 320 CDi Sport LWB uprated by Brabus to 300Bhp don't know if there's a 155mph limiter - will be fun finding out! 2004 Mercedes Vaneo 1.7 CDi Ambiente 7-seater
VelSatisfied is offline   Reply With Quote Quick reply to this message
Reply
Tags
engine, runaway, runs, smoke, starts, turbo, white
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
