how do i change the sidelight bulb on my scenic 2007 - Page 2 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 10th October 2012   #6
coup
coup is
TT
Platinum member
coup's Avatar
Nominated 6 Times in 17 Posts
Nominated TOTW/F/M Award(s): 5
Re: how do i change the sidelight bulb on my scenic 2007
The led ones are a direct replacement..course you can get capped(with glass ) and uncapped led also.The uncapped may have like 6-8 leds on a flat face or even more on a stick in that fitting.
The principle should be the same .. pull out the old bulb and insert the new.
If you dont have the old bulb holder in your hand with the bulb in it, you will have to pull it out with gentle twisting on mine.If the scenic has some seperate locking mechanism.. thats another story.
Oh test the bulb while the holder is out of the headlamp unit as the led's are sensitive to current direction. You may have to turn the bulb 180 degrees to get it to light.
__________________
KHAAAAAN!
Currently in coup's garage:
RM III coupe 1.5dci FVT,Audi TT Mk1 ,a bike and too much rubbish.
coup is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11th October 2012   #7
speedyduck
speedyduck is
has no status.
Junior Member
Threadstarter
speedyduck's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
That's great mate. But how do I locate the bulb. There does not seem to be any direct access to the bulb. The plug pulls downward but it plugs into a greyish plastic moulding that is an L shape. Assuming bulb is in here somewhere but don't know how to gain access. Help!!!!
Currently in speedyduck's garage:
2007 grand scenic 1.9tdi (130)
speedyduck is offline   Reply With Quote Quick reply to this message
Old 11th October 2012   #8
mseh
mseh is
has no status.
Member
mseh's Avatar
Nominated 0 Times in 2 Posts
The quickest way is take off front bumper 20 mins job . Undo the plastic screws on the top bumper, undo the three or four 10 mm bolts underneath it. And the two little bolt screws in both front wheel arches. Then the bumper should just pop off
Currently in mseh's garage:
grand scenic 2008 1.9dci non FAB
mseh is offline   Reply With Quote Quick reply to this message
Old 17th March 2013   #9
speedyduck
speedyduck is
has no status.
Junior Member
Threadstarter
speedyduck's Avatar
still no closer to finding out how to replace the bulb. It is a h6w type .Any further help would be appreciated
Old 16th December 2013   #10
tomaljack
tomaljack is
has no status.
Junior Member
Quote:
Originally Posted by speedyduck View Post
Can't go to Halfords as I am replacing bulbs with led bulbs. Bulbs are not the cap less ones as on earlier versions but bayonet with offset pins
Hi Speedyduck, I've just been reading you posts from last year. I'm looking to replace my h6w with LEDs but haven't found a set that work without flickering. Everything I've read on line assumes 501s are installed.
Did you manage to sort yours out and if so what did you use?
tomaljack is offline   Reply With Quote Quick reply to this message
Reply
Tags
2007, bulb, change, scenic, sidelight
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
