Renault Clio 2002 passenger door will lock but not unlock - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Interiors
Notices
Interiors Discuss leaks, seats, carpets etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Interiors
Reply
Thread Tools Display Modes
Old 13th November 2012   #1
SBroad
SBroad is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have recently bought a Renault Clio Extreme 2002. Really pleased with it apart from the minor fault when I bought it. The central locking works fine, I can push the remote and the car will lock - however if I then unlock it, the drivers door and the boot will unlock but the passenger door will not unlock, to get in I have to pull the handle of the passenger door inside the car. It then remains unlocked until I lock the car again.
I tried taking the door panel off today - took 4 screws out of bottom of door, took door handle off disconnected rod, but the door panel still seemed very very firm, I was worried about breaking it or whatever so I decided to put the screws back and seek some help here.
When I put the key in the door it will go in fine but when I try to turn it - it doesn't want to turn it feels almost as if I'm forcing it, whereas the drivers door turns fine and can unlock the door manually myself.
Thanks for ur help in advanced.
Currently in SBroad's garage:
2002 Renault Clio Extreme
SBroad is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by SBroad
Renault Clio 2002 passenger door will lock but... Interiors lancs dave 2 2956 13th November 2012 06:25 PM
Sponsored Links
Advertisement
Old 16th November 2012   #2
SBroad
SBroad is
has no status.
Junior Member
Threadstarter
Re: Renault Clio 2002 passenger door will lock but not unlock
I got the door panel off today and got access to the lock. I have tried spraying WD40 on anything I see moves but still no luck.
I can feel the lock doing something as the white box which has got the plug connecting moves of some kind as I can feel it when I hit the button on the remote. I disconnected the plug too and it never did anything so I know the connections are ok electrically.
When I push the latch up to the lock position the key will not unlock the door, it moves but does not move to the unlock position. I sat in the car and I could see the lock barrel not being able to go down. To unlock the door I pull the door Handel rod from inside and it opens fine.
I don't know if it could be the solenoid, so confused with it!!
Old 16th November 2012   #3
lancs dave
lancs dave is
struggling to get in gear
Platinum member
Technical Supremo
lancs dave's Avatar
Nominated 13 Times in 26 Posts
Nominated TOTW/F/M Award(s): 12
It might be better to remove the lock from the door to test. This will allow you to test the lock barrel at the same to see if it works with the main lock out of the way.
Should be plenty on ebay if you need one.
Currently in lancs dave's garage:
Less rubbish now I've been to the tip.
lancs dave is offline   Reply With Quote Quick reply to this message
Reply
Tags
clio, door, lock, passenger, renault, unlock
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
