remap vs tuning box question - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 20th December 2012   #1
scaredpassenger
scaredpassenger is
hungry like a wolf!
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I've read quite a lot about the differences of the two, but the power outputs quoted by nearly all tuning box companies is pretty much the same output quoted by any remap company, whilst i understand that tuning boxes just mess around with fueling levels hence being limited to the max fuel flow rate and then having a top end of performance, will a decent remap not be able to change the turbo pressure as well as fueling parameters
or is it a case that the clio dci 100ps ecu is clever enough to see the extra fuel being chucked in on the tunning box front that it can then adjust turbo pressure and together that gives you the overall power output?
I'm fully aware that the turbo fitted to my car is a vgt!
Currently in scaredpassenger's garage:
2004 clio dci 100, and a 2012 Vauxhall GTC VXR
scaredpassenger is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by scaredpassenger
remap vs tuning box question Engines coup 2 1180 20th December 2012 06:48 PM
what reader for codes required Electronics spacecadet 14 1883 19th December 2012 01:34 PM
clio 1.5dci 100 loss of power and intermitent... Engines scaredpassenger 4 1483 8th June 2012 11:45 AM
clio cabasse stereo upgrade issues In-car entertainment scaredpassenger 1 1632 7th March 2012 02:56 PM
Sponsored Links
Advertisement
Old 20th December 2012   #2
VelSatisfied
VelSatisfied is
International, but his heart is always where the weather's nice.
S.M.A.R.T.(y) Pants
VelSatisfied's Avatar
Nominated 11 Times in 37 Posts
Nominated TOTW/F/M Award(s): 17
Re: remap vs tuning box question
In all honesty, I have had one car remapped (which delivered a fantastic transformation), and I'm (personally) a bit suspicious of boxes (although I have no experience of them).
To my mind, the box is a generic solution whereas the remap is specific for the driver's car & driving style.
I draw the analogy between going into a shoe shop, and buying blind, versus buying a pair the correct size - sure, the outcome is the same (a pair of shoes), but the way they perform will differ.
Plus, I think if you deal with an individual face-to-face (who does the conversion), you have a bit more recourse if it goes pear-shaped, than some company off the internet who may simply wash their hands & hide behind the small print.
Maybe I'm just overcautious, but an engine is a very expensive item if it goes bang.
HTH,
Paul
__________________
This job should never be complete - the day I think I've done it all, is the day I resign.
S.M.A.R.T. Technician
Currently in VelSatisfied's garage:
2005 FIAT Ducato 2.8JTD LWB Gran Volume, 2000 Kawasaki ZZR 1100 D7 'fullpower' in black + full GIVI & KAPPA luggage, 2007 MB R-Class 320 CDi Sport LWB uprated by Brabus to 300Bhp don't know if there's a 155mph limiter - will be fun finding out! 2004 Mercedes Vaneo 1.7 CDi Ambiente 7-seater
VelSatisfied is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to VelSatisfied For This Useful Post:
coup (20th December 2012)
Old 21st December 2012   #3
coup
coup is
TT
Platinum member
coup's Avatar
Nominated 6 Times in 17 Posts
Nominated TOTW/F/M Award(s): 5
I think of the tuning box as the pure diesel tuning,in the sense that it fool the car into injecting more fuel than the original ecu map specifies for any given condition.
If we take the view that the boxes really the same, how effective one will be seems to depend on how much tolerance is built into your engine type.
I have only had direct experience of a "box" on a 90 bhp diesel,but Ive read others experience of what is probably a very similar box on the 110bhp version of the same engine.
What I get with my "box"is approximately (I think)a 115bhp type engine at hi and medium revs and something that can actually improve fuel economy if its kept on the torque curve (around 1750-2250)
If I drive it hard ..like revving to the dizzy heights of 4000+ in the gears the mpg will be worse than normal..
The impression I get from people with a box on 110bhp versions of the same engine is that they get ,maybe a 120 bhp engine at hi revs and close to a 125/130 bhp and medium revs
The torque kick is big..no doubt..higher performance wont go up much unless your fuel system is understressed as standard.
The above engines have a different turbo but are pretty much the same otherwise..
The easiest to understand diesel tuning quote ive read is :
"Add more fuel till it smokes, then add more turbo pressure,then add more fuel "..and so on.
Tuning boxes just fool the ecu into adding more fuel at any given time/load requirement.The original map is set to add the minimum amount of fuel for the same situation.
Ehats with the economy claims on tuning boxes then?.
I think its a case of holding a low rev /hi torque state even more rigourously than than the manufacturers allow for.
With a box you get a good acceleration "kick" compared to without, but the "torque curve" seems narrower.
Turbo pressure adjustment:
The common box cant affect that directly..how could it,its just a variablle resistor in the fuel pressure sensor feedback.
with a box all you get is more fuel pressure,up to the sensors limits.
There are 3 sensor tuning boxes around for alfa multijet engines..I dont know how good they are but to get it set right you would think remaps would need to be involved too.
It seems like ,if your engine has a reasonable fuel pressure safety margin.you can get ok results.
Mine is 1650bar max normal operating pressure..just like the 110bhp version but cos its in a lower state of tune it might not go to 1650bar as often.
The sensor for both engines goes to error at approx 1800 bar.
The remap,if its a good one, you would think should provide the fuel and the extra turbo pressure,at least if its a vvt turbo and its max pressure isnt contrilled mainly by a physical wastegate.
A good remap should provide more than you would get from a tuning box as the tuning box is really dependant on a best case scenario in terms of fuel pressure headroom.
There are remaps which use tuning boxes!..shows the importance of fuel pressure probably.
Cost.. well there you come to a big q...My box £35 second hand.A remap..£300 for a good one?..200,I dont know.
After 18 months on the box..I have I think at least a 20% better overall result.
A remap alone might be better .
For example I cant go over lvl 7 on my box to be 100% sure of no errors perhaps with a remap I could get to use up tothe level 9 max(0-9) all the time.
Doesnt really matter,I wont be getting a remap till guarantee is gone anyway.
It be too difficult to change back for service.
__________________
KHAAAAAN!
Currently in coup's garage:
RM III coupe 1.5dci FVT,Audi TT Mk1 ,a bike and too much rubbish.
coup is offline   Reply With Quote Quick reply to this message
Old 10th January 2013
kunjan008007
This message has been deleted by VelSatisfied. Reason: breach of forum rules - unofficially advertising their own business.
Reply
Tags
box, question, remap, tuning
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
