1999 scenic - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
1999 scenic
Engines
Reply
Thread Tools Display Modes
Old 30th December 2012   #1
simonash
simonash is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
1999 scenic
hello can anyone help me , i have a 1999 1.6 scenic and my alternator belt come off and shredded up and my car would not start, can any one help as i can not seem to ge tmy newbelt on as i can not seem to loosen off the altenator to fit the new belt, thanks
Currently in simonash's garage:
t reg 1999 renault megane scenic rt alize
simonash is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by simonash
1999 scenic Engines wyn burgess 1 673 30th December 2012 12:04 AM
Sponsored Links
Advertisement
Old 30th December 2012   #2
wyn burgess
wyn burgess is
has no status.
Diamond member
Nominated 2 Times in 4 Posts
Re: 1999 scenic
Not sure if your car has AC but to release the alternator you have to loosen the small adjuster nut, undo the 13mm clamp bolt beneath the adjuster and loosen the alternator pivot bolt which is the long bolt behind the alternator. Worth removing the timing belt covers to remove any hidden debris and turn the engine over by hand before starting as the debris may have caused the timing belt to jump a tooth.
Currently in wyn burgess's garage:
2000 Scenic 1.9 Dti. 1999 Clio 1.2 best car, 807 2.2, 1971 Triumph T25 T/B
wyn burgess is offline   Reply With Quote Quick reply to this message
Reply
Tags
scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
