Clio rear number plate light - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Clio
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Clio
Reply
Thread Tools Display Modes
Old 26th December 2006   #1
dartiss
dartiss is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My rear number plate light is out. The bulb has obviously blown but a replacement (in fact two replacements) hasn't resolved it.
Neither the Clio manual nor the corresponding Haynes manual throws any light onto which fuse this light is using. Does anybody know?
The connections to the light are badly corroded so that's another possibility (I've given it a clean and a WD-40 spray).
All help appreciated.
David.
Currently in dartiss's garage:
2002 Renault Clio 1.2 16v Extreme
dartiss is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by dartiss
Steering Wheel Interiors VelSatisfied 5 2012 20th July 2007 05:50 PM
Buying a 1998 Clio Biarritz Clio chris m 3 1929 18th July 2007 02:09 PM
SatNav and Clios Electronics L40 REN 4 1382 26th December 2006 05:10 PM
Clio rear number plate light Clio freddybabe 22 22520 26th December 2006 11:30 AM
Main beam wouldn't turn off Clio MatthewLevene 4 3223 20th November 2006 03:27 PM
Sponsored Links
Advertisement
Old 26th December 2006   #2
Horatio
Horatio is
has no status.
Platinum member
Horatio's Avatar
Nominated 0 Times in 7 Posts
Nominated TOTW/F/M Award(s): 8
On most cars, it's just fed from the side light circuit(s). If both tail side lights are working, then I doubt it's a fuse.
Pop out the holder again and test the voltages to both contacts with respect to a good earth (e.g. the bolts on the tailgate striker.) Do this with a good bulb in place and the lights turned on. You'll get one of the following results.
0v on one wire, 12v on the the other. Either the bulb is faulty or there's an internal fault in the bulb holder. This could be one of your corroded contacts
12v on both wires. There's a bad earth to the number plate lamp. You'll need to repair this, though it's often easier just to run a fresh earth wire.
0v on both wires. You have a poor connection to the source light cluster. Again, you can try to trace and repair this but it's often easier just to run a fresh wire.
Currently in Horatio's garage:
2010 Laguna III Initiale.
Horatio is offline   Reply With Quote Quick reply to this message
Old 27th December 2006   #3
eggy790
eggy790 is
has no status.
Diamond member
its a common fault on clios.. happens to mine and 3 other clio owners i know.. basically jst take the cover out and fiddle/move the wires.. i think its lose connection.. coz it comes bak on after a while then goes off sometimes if knocked.. but like my aunties she had no problem with her light till i couldnt figure out why mine wasnt workin and wanted to see her connection lol, and then mine started working and hers stopped as soon as i took cover off and put it back in. jst needed a lil moving around.
jst play with the wires, it'll come bak on.. may go on and off with the boot slammin and knockin wires but jst make sure its workin for Mot.
Currently in eggy790's garage:
2000 (W) Renault Clio Alize 1.4 16v
eggy790 is offline   Reply With Quote Quick reply to this message
Old 27th December 2006   #4
Truckbusuk
Truckbusuk is
A diesel convert but 5* at heart!
Truckbusuk's Avatar
Nominated 0 Times in 2 Posts
Nominated TOTW/F/M Award(s): 2
This problem is usually corrosion in the connector from the wiring loom.
Best fix is either to cut it off and crimp replacement female spades terminals or use a fibreglass pencil and carefully clean the connector and the light fitting, then spray with a contact cleaner and some water dispersant (WD40 or similar) .... the cleaning method usually works it just takes time, if the corrosion is really bad then the only option is to replace the connector.
Hope it helps
__________________
Why is it the older I get .... the better I think I was ?
Currently in Truckbusuk's garage:
Clio2 1.4RT Phase1(VF1BB0S) + Volvo XC90 SE Lux D5 Geartronic
Truckbusuk is offline   Reply With Quote Quick reply to this message
Old 4th January 2007   #5
paul01207
paul01207 is
has no status.
Junior Member
Smile
Its fuse 26, Although this fuse also controls passenger tail light and front passenger side light, and dash board ilumanation. Its a 10v red fuse, if say your rear passenger tail light is still working the fuse is fine, and its the wires or conector or bulb.
Currently in paul01207's garage:
1998 clio 1.2
paul01207 is offline   Reply With Quote Quick reply to this message
Reply
Tags
clio, light, number, plate, rear
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
