trekka low pressure pump - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 8th January 2013   #1
madmick22
madmick22 is
has no status.
Junior Member
Nominated 0 Times in 1 Post
TOTW/F/M Award(s): 0
Question trekka low pressure pump
Could anyone please tell me where the low pressure fuel pump is situated on a 2003 trekka 1.9 dci mk1 model
cheers
Currently in madmick22's garage:
2003 kangoo trekka 1.9dci
madmick22 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by madmick22
trekka 1.9 dci starter motor Engines wyn burgess 1 649 8th January 2014 03:56 PM
trekka 1.9dci propshaft Transmissions spacecadet 1 595 30th April 2013 02:17 PM
trekka low pressure pump Engines madnoel10 1 563 8th January 2013 03:28 PM
trekka 1.9dci tdc help Engines madmick22 0 527 3rd December 2012 07:22 PM
trekka ,problem Engines madmick22 3 737 1st December 2012 09:21 PM
Sponsored Links
Advertisement
Old 8th January 2013   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: trekka low pressure pump
It may be located either aorund the right-hand wheel arch area or down the back of the engine. Follow the fuel lines back from the fuel filter you're bound to bump into it.
Not all models have a primary pump. If it has a rubber primer bulb then no electrical promer bump was fitted when new.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to madnoel10 For This Useful Post:
madmick22 (8th January 2013)
Reply
Tags
low, pressure, pump, trekka
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
