Megane Scenic misfire P0300 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 5th February 2013   #1
wightmanp
wightmanp is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have a Renault Scenic 55 reg 1.6l petrol. It has develeoped what feels like a misfire at around 2-2,500 revs. Below and above that range the engine runs well and pulls hard to the red line. When it misfires there is a noticeable vibration from the lower front end of the car.
Engine diagnostic shows OBD code P0300 - random multiple cylinder misfire. Plus P0340P as a provisional code - Camshaft position sensor malfunction. Plus the usual "check emmissions" warnings
The misfire has to effect more than 1 cylinder for this code to appear. Plugs, leads, coils could be to blame but before I start random replacements of parts i wonder whether anyone else has come across this type of fault. Cheers.
Currently in wightmanp's garage:
Rernault Megane Scwenic 2006 1.6i
wightmanp is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by wightmanp
Megane Scenic misfire P0300 Engines wightmanp 2 5128 5th February 2013 05:40 PM
Sponsored Links
Advertisement
Old 5th February 2013   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Megane Scenic misfire P0300
Firstly Renaults use a different protocol in their ECU's so the fault code you have may be totally misleading. In other words take it with a great big pinch of salt.
First thing to check would be the spark plugs - what colour are they - are they all of the same colour. That may give a clue as to which cylinder is at fault.
Also the spark plugs are wired in pairs so it is not uncommon for two cylinders to be affected.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 5th February 2013   #3
wightmanp
wightmanp is
has no status.
Junior Member
Threadstarter
Thanks for the advice. I'll give the plugs a try first.
Reply
Tags
megane, misfire, p0300, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
