Ecu fault - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Ecu fault
Engines
Reply
Thread Tools Display Modes
Old 18th February 2013   #1
DPICK
DPICK is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Ecu fault
Hi I'm in need of help I have a trafic 115 van on a 08 plate that started drove for 10 foot and conked out. Towed to Renault dealer which said it's the high pressure fuel pump. Took to another garage which agreed so they fitted a reconditioned pump on. They are now telling me pressure at injectors but no diesel being sprayed in and fault code coming up as ecu fault does new pump need coding to ecu or any other suggestions would be appreciated.fault code coming as P0606.
Currently in DPICK's garage:
Trafic
DPICK is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by DPICK
Engine not starting Engines DPICK 2 913 2nd April 2013 08:42 PM
Ecu fault Engines DPICK 2 1483 18th February 2013 12:47 PM
Fuel System Problem Renault Trafic 2008 Engines mickeybo 3 2181 8th January 2013 08:41 PM
Sponsored Links
Advertisement
Old 18th February 2013   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Ecu fault
The fault code you have is generic and therefore may be totally misleading.
Renault use a different protocol in their ECU's so I suggest you get the codes read by a code reeader that is fully compatible
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 18th February 2013   #3
DPICK
DPICK is
has no status.
Junior Member
Threadstarter
Re: Ecu fault
Thanks for your reply madnoel.ive looked up code and they reckon the PCM needs re flashing or replacing whatever the PCM is. Totally ****ed off with this van now any ideas welcome.
Trafic
Reply
Tags
ecu, fault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
