Clio 1.2 2000 Engine cut out suddenly - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 21st February 2013   #1
redshift
redshift is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Angry Clio 1.2 2000 Engine cut out suddenly
The engine was running and cut out suddenly. It wil not start. Engine strains to turn over, but only a very very weak, or no starter effort. Is it an alternator problem or what? Battery ok.
Currently in redshift's garage:
2001 Renault Clio 1.2
redshift is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by redshift
Clio 1.2 2001 rear brakes very weak Brakes/Hubs whizzy41 7 1129 10th July 2014 11:26 PM
Clio 1.2 2000 panel lights off following engine... Electronics redshift 0 626 10th August 2013 12:43 AM
Renault Clio 2000 1.2 starting problem Engines redshift 6 1889 17th July 2013 05:51 PM
Clio 1.2 2004 Engine management code: meaning of Engines mickeybo 8 5088 25th March 2013 11:28 PM
Clio 1.2 engine noise - like tappets; but not. Engines redshift 3 1418 7th March 2013 09:15 PM
Sponsored Links
Advertisement
Old 21st February 2013   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Clio 1.2 2000 Engine cut out suddenly
Start by checking the battery. Will the engine start on a push, tow or using jump leads?
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 21st February 2013   #3
redshift
redshift is
has no status.
Junior Member
Threadstarter
Unhappy Re: Clio 1.2 2000 Engine cut out suddenly
Battery ok; I even supplemented it with another good battery via jump leads. It's as if the starter is straining to rotate; lights, etc. dim severely. But a jammed/faulty starter would not have caused it to cut out in first place?? or was that one of those coincidences?
Old 21st February 2013   #4
redshift
redshift is
has no status.
Junior Member
Threadstarter
Have not yet tried push start or towing. Will try that tomorrow.
Old 21st February 2013   #5
lancs dave
lancs dave is
struggling to get in gear
Platinum member
Technical Supremo
lancs dave's Avatar
Nominated 13 Times in 26 Posts
Nominated TOTW/F/M Award(s): 12
Check the flat braided earth strap from gearbox to inner wing.
Look from under the wheel arch with steering on full lock.
They can rot and can give slow cranking issues. Could also cause cutting out as some engine electrics will use the same earth path.
Also check battery to body earth points are clean and sound.
Click image for larger version
Name:	Copy of clio CBO5 015.jpg
Currently in lancs dave's garage:
Less rubbish now I've been to the tip.
lancs dave is offline   Reply With Quote Quick reply to this message
Reply
Tags
clio, cut, engine, suddenly
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
