renault clio electrical problem - Page 2 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 3rd March 2013   #6
lancs dave
lancs dave is
struggling to get in gear
Platinum member
Technical Supremo
lancs dave's Avatar
Nominated 13 Times in 26 Posts
Nominated TOTW/F/M Award(s): 12
Re: renault clio electrical problem
Have a look at the pics and choose an option
Click image for larger version
Name:	Clio mk2 phase1.jpg
ID:	18334   Click image for larger version
Name:	Clio mk2 phase2.jpg
Currently in lancs dave's garage:
Less rubbish now I've been to the tip.
lancs dave is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 3rd March 2013   #7
kenpawson
kenpawson is
has no status.
Junior Member
Threadstarter
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Smile Re: renault clio electrical problem
hi, its the one on the left mk2 phase 1
Currently in kenpawson's garage:
2001 renault clio
kenpawson is offline   Reply With Quote Quick reply to this message
Old 3rd March 2013   #8
lancs dave
lancs dave is
Platinum member
Technical Supremo
lancs dave's Avatar
As far as I know, the early mk2 like yours has a relay fitted to the uch behind the fusebox on the dash.
By rights it shouldn't be putting a feed to the rear screen until the button is pressed.
The relay could be stuck or the button faulty meaning it's giving a live as soon as ignition is on.
That doesn't really explain why it's blowing the fuse unless you also have a short in the wire to the screen as well.
Not sure if the circuit goes from fuse to relay or other way round.
It would be worth unpluging the relay in the first instance and seeing if it still blows the fuse.
Might be able to piont out the relay if you can pull down the uch and post a picture of the relays on it.
Old 3rd March 2013   #9
kenpawson
kenpawson is
has no status.
Junior Member
Threadstarter
does the fuse to the heated rear window also feed wash bottle motors and rear wiper unit as these also are not working, and have checked for supply at wash bottle motor in engine bay using a multimeter and no voltage is present when wash switch is operated, all other fuses are ok only the one marked as heated window is blowing?
2001 renault clio
Old 3rd March 2013   #10
lancs dave
lancs dave is
Platinum member
Technical Supremo
lancs dave's Avatar
Welcome to the wonderful world of Renault wiring.
"Spare wire here boss"
"Yeah, just stick it in with any other you can find"
There are variations but yes, the rear wiper/washers might be on the same circuit.
There might be a live to one of it's wires once ignition is on. Probably for the ' park ' position.
Have you had a look in the rubber boots between the roof and tailgate. Wires can get snapped and touch.
Also try disconnecting wiper motor
Reply
Tags
clio, electrical, problem, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
