2006 Renault Kangoo 1.6 K4M. Broken timing belt set timing - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 12th March 2013   #1
06kangooo
06kangooo is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question 2006 Renault Kangoo 1.6 K4M. Broken timing belt set timing
Hi Guys,
I'm a newbie here and I'm hoping to get some advice to get me motoring again. My cam belt broke on my 2006 1.6 Kangoo whilst my car was at idle. I'm hoping for not to much damage to valves and have decided to put on a new belt and hope for the best (Fingers crossed). My problem is, I didn't mark the cam and crank pulleys when the belt broke. I do have marks from the previous belt change though (Cams only).
My question is, can I get away with out having the timing locking tools for the cams and locking pin for the the crank? Can I use a drill bit or similar to lock the flywheel / crank and is a pin the easiest way to find TDC?
Currently in 06kangooo's garage:
06 Kangoo
06kangooo is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by 06kangooo
Head or complete engine - 05 Kangoo. Engines madnoel10 17 1826 17th October 2014 09:36 AM
Kangoo Clio Engine swap Engines 06kangooo 0 634 16th October 2014 02:10 AM
Emergency fuel cut off 06 1.6 Kangoo Engines Ralph 1 1757 22nd March 2013 08:48 AM
2006 Renault Kangoo 1.6 K4M. Broken timing belt... Engines bugsb 4 9875 12th March 2013 10:57 AM
Newbie Welcome to RenaultForums IT66 2 540 12th March 2013 10:33 AM
Sponsored Links
Advertisement
Old 12th March 2013   #2
bugsb
bugsb is
at home
Platinum member
bugsb's Avatar
Nominated 14 Times in 11 Posts
Nominated TOTW/F/M Award(s): 2
Re: 2006 Renault Kangoo 1.6 K4M. Broken timing belt set timing
you can make the tdc pin from a bolt i cant remember off hand the size also 5mm bar will make the cam locking tool
but for a couple of quid you may as well get the crank pin
Ron
Currently in bugsb's garage:
MGF 1.8 1999/honda hrv 2002
bugsb is online now   Reply With Quote Quick reply to this message
Old 12th March 2013   #3
S80
S80 is
has no status.
Diamond member
Nominated 0 Times in 1 Post
"My problem is, I didn't mark the cam and crank pulleys when the belt broke" - ????
Don't bother trying to re-fit the belt, valve damage will have occurred.
Compared with the overall cost of the repair job, the timing tools are cheap enough to buy.
Currently in S80's garage:
Megane I Phase 2 1.8 5dr
S80 is offline   Reply With Quote Quick reply to this message
Old 13th March 2013   #4
owenstringer
owenstringer is
Taking my private pilots liscence
Diamond member
If you have marked the cams in the past then you will have no problem there. on the K4M the crank should be positioned so that the key slot is at the 12 oclock position. im not sure what size the locking pin is i cant remember but if i m right in thinking im sure is 8mm thread.
Currently in owenstringer's garage:
Megane 2 1.6 dynamique 2004
owenstringer is offline   Reply With Quote Quick reply to this message
Old 14th March 2013   #5
bugsb
bugsb is
at home
Platinum member
bugsb's Avatar
with out the cam locking tool one cam will move the tool stops this from happening
Ron
Reply
Tags
2006, belt, broken, cam belt, k4m, kangoo, renault, set, timing, timing belt
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
