1999 reg megane not starting wont prime fuel or spark or plug in to diagnostic - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 12th March 2013   #1
bad renau1t
bad renau1t is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
hi i have just bought a renault megane wityh the timing belt snapped so i stripped it down and put valves in ect ect.. but when coming to start it it did not fire. i pulled the fuel line off to see if there was any fuel gettin up and there was nothing so thought it might be the fuel pump so tested it in another car it works fine so thought it was the relay checked that works fine but still doesent prime and it is not sparking whitch sounds to me like an ecu fault or imobiliser fault tryed pluging it in to my mates snap on diganostics and it wont connect checked all fuses still no luck can anyone help me got an headache on my hands i think
Currently in bad renau1t's garage:
renault megane convertible
bad renau1t is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by bad renau1t
can i bypass the imobiliser on a 1999 renault... Electronics planmeca 4 921 16th March 2013 11:36 AM
why wont my megane connect to diagnostics Engines mickeybo 3 1365 15th March 2013 10:38 AM
megane no power to the fuel pump and no spark Electronics bad renau1t 3 2470 13th March 2013 09:49 PM
starting problem with my megane 1999 converible Engines bad renau1t 4 1717 13th March 2013 09:59 AM
renault megane 1999 wont connect to diagnostics Engines bad renau1t 4 1685 13th March 2013 09:09 AM
Sponsored Links
Advertisement
Old 12th March 2013   #2
bugsb
bugsb is
at home
Platinum member
bugsb's Avatar
Nominated 14 Times in 11 Posts
Nominated TOTW/F/M Award(s): 2
Re: 1999 reg megane not starting wont prime fuel or spark or plug in to diagnostic
has the fuel cut off switch been tripped as i am sure it cuts out the spark at the plugs as well
i think its behind the battery on the 99 model but not 100%
Ron
Currently in bugsb's garage:
MGF 1.8 1999/honda hrv 2002
bugsb is online now   Reply With Quote Quick reply to this message
Old 13th March 2013   #3
bad renau1t
bad renau1t is
has no status.
Junior Member
Threadstarter
hi ron i have tryed the fuel cut out switch . and on the fuel relay it says on auto data to bridge it with a piece of wire so did that and it sent fuel up but wont work with a different relay. my head gone with it am unsure what else it can be other than the ecu but i have two keys and they both unlock the car and when you put the key in the red light stays solid for abit so that mean the imobilier is working doesent it. tryed pluging the diagnostics in but it wont connect to the car is there a data link fuse do you know of ron thanks
Reply
Tags
diagnostic, fuel, megane, plug, prime, reg, spark, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
