How to remove door card for Megane Coupe MK3 - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Interiors
Notices
Interiors Discuss leaks, seats, carpets etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Interiors
Reply
Thread Tools Display Modes
Old 3rd June 2013   #1
daveb84
daveb84 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi All
Really appreciate some help on door card removal for mk 3 Megane coupe.
Either a guide or pics or even just how many crews there are to remove, where they are and where to apply pressure.
Also tools needed?
Really appreciate any help.
Currently in daveb84's garage:
2009 Renault Megane 1.6 World Series
daveb84 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by daveb84
World Series front spoiler Bodywork VelSatisfied 3 1344 4th November 2013 10:41 AM
How to remove door card for Megane Coupe MK3 Interiors daveb84 6 6465 3rd June 2013 03:49 PM
Megane coupe MkIII after market speakers Electronics daveb84 2 2750 28th May 2013 01:15 PM
Sponsored Links
Advertisement
Old 3rd June 2013   #2
coup
coup is
TT
Platinum member
coup's Avatar
Nominated 6 Times in 17 Posts
Nominated TOTW/F/M Award(s): 5
Re: How to remove door card for Megane Coupe MK3
Id like to be of help, but have no idea what the door card is, sorry.
Currently in coup's garage:
RM III coupe 1.5dci FVT,Audi TT Mk1 ,a bike and too much rubbish.
coup is offline   Reply With Quote Quick reply to this message
Old 4th June 2013   #3
daveb84
daveb84 is
has no status.
Junior Member
Threadstarter
Hi coup
the door card is just the inside door panel.
Any help much appreciated. Trying to change the speakers!
Old 4th June 2013   #4
Raynult
Raynult is
almost nearly quite good at some things
Diamond member
Nominated 0 Times in 4 Posts
I've not taken one of a Megane Coupe but I have taken them of several other cars, Megane, ZX and BX.
As you're changing speakers, first thing I'd take a look at is removing the speaker covers/grills, you may be able to change them without removing the door card.
They're all pretty similar but you may have to find your way around a bit. Also, Renault tend to use Torx screws, the insert for putting a driver in looks like a star.
1) Take off your window winder if you have one, usually prising it off with a broad blade screw driver will do.
2) Remove arm rest/door grab handle, screws usually underneath.
3) There's often a screw in the plate behind the openeing catch. Leave the catch in situe, just feed it through the card as you remove it.
4) You may have to remove/prise off a cover inside the door where the mirror is.
5) If there's a door pocket at the bottom, there will be a couple of screws underneath holding it place.
The card is then hung onto the inside of the door in the window socket, with a combination of plastic lugs and mastic around the perimeter of the card holding it in place. Usually none under the window socket.
You'll need a sharp knife to cut the mastic, and a broad bladed screw driver or special tool to prise out the door lugs. Be careful and take your time, these lugs can break fairly easily. Start at one of the bottom corners and work your way around.
Once inside, take care to removing any electrical connections.
(The special tool looks like a 2 wide pronged fork which is shaped rather like an ordinary dining fork, prongs shorter and stronger)
Raynult is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Raynult For This Useful Post:
anesa_h (15th August 2013)
Old 4th June 2013   #5
daveb84
daveb84 is
has no status.
Junior Member
Threadstarter
Cheers Raynault I'll give that a go. Is it a fairly easy task getting it back on again?
Thinking of just getting someone todo it for £50 to save me the hassle/worry!
Reply
Tags
card, coupe, door, megane, mk3, remove
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
