Laguna II ESP problem - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 19th June 2013   #1
DePhazz
DePhazz is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Laguna II ESP problem
Hi all, I'm new to the forum and apologize if thread is not in its right place.
I bought Laguna II 2002, 2.0IDE with mechanical gearbox just two days ago and has drove around 100km. Today morning after driving around 15km the ESP warning came on dashboard requiring service. It writes "registering ESP" with car indicator, then comes another indicator stating "registering service" or something like that (I'll check and get back later). I tried to switch off ESP while driving but no reaction. I stopped, turned engine off, turned it again and after 100 meters same error again. One more thing that happens is motor does not go more than 2k rounds per minute, whatever the gear. Is it normal?
I browsed this forum and most common problem I found was ESP/ABS problem together, but in my case only ESP warning comes out.
Note that I haven't touched anything like wheels or ABS system.
Can pressure in the tyres cause this problem? Or what can be the cause of it?
Thanks in advance.
Currently in DePhazz's garage:
Renault Laguna II 2002, 2.0IDE
DePhazz is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by DePhazz
Laguna MK2 power steering fluid level Steering and Suspension Adamv211 4 350 9th October 2015 10:29 AM
Laguna II 2.0IDE gearbox problem Transmissions DePhazz 0 477 30th May 2014 06:19 AM
Laguna II 2.0IDE engine, what's that on the pic? Engines dave_mezza2006 4 1010 16th September 2013 11:25 AM
Can't decode radio Electronics DePhazz 4 1262 8th August 2013 11:50 AM
Tic-tac noise while in neutral Transmissions Prickleypear 11 2042 3rd July 2013 03:34 PM
Sponsored Links
Advertisement
Old 19th June 2013   #2
dejan72
dejan72 is
automatic
Diamond member
dejan72's Avatar
Re: Laguna II ESP problem
Similar happened to me yesterday too. ESP system failure voice message. I guess it must be heat related. Will see tomorrow morning.
DG
Currently in dejan72's garage:
2002 laguna V6 24V
dejan72 is offline   Reply With Quote Quick reply to this message
Old 20th June 2013   #3
DePhazz
DePhazz is
has no status.
Junior Member
Threadstarter
Just to update.
I arrived at work in the morning with the problem mentioned above. In the afternoon I switched off ESP while key in the slot, engine not running, and went to local service. While driving I switched on ESP again and drove around 10 km without errors on the dashboard.
I made electronic diagnostics and several errors appeared in the memory that we cleared. Service guy said the problem might be because of memorised errors. Now it's clear, we drove quite aggressively on wet surface and ESP worked fine.
Since then I drove around 100 km and no errors until now.
Hope it continues the same way :D
Reply
Tags
esp, laguna, problem
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
