Crankshaft Pulley.... - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 16th July 2013   #1
ShogunsElite
ShogunsElite is
taking the head off the megane.... again!
Junior Member
ShogunsElite's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Crankshaft Pulley....
My Megane got hungry and decided to eat the drive belt, alot of it is caught up behind the Crank pulley for the drive belt.. Can I take the crank pulley off without messing up the timing or do i risk messing up the timing taking the bolt out to remove that pulley? I was warned that if i go on ahead and remove that bolt it may mess up the timing but was hoping somone could help me please?
baring in mind i do not plan on touching the timing belt!
Currently in ShogunsElite's garage:
2005 Megane 2005 1.5 DCI and 2001 Citreon Saxo 1.5 diesel
ShogunsElite is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by ShogunsElite
Crankshaft Pulley.... Engines martin15s 6 1060 16th July 2013 10:33 PM
Sponsored Links
Advertisement
Old 21st July 2013   #2
martin15s
martin15s is
has no status.
Junior Member
Re: Crankshaft Pulley....
I locked the crankshaft with a small torx bit wedged the flywheel and bell housing (easily accessible from under the car). Undo the pulley bolt (which should be very tight) and try to remove the pulley. It is a push fit - there is no woodruff key - and you may need a "suitable" puller. Provided that you do not try to rotate the crankshaft and camshaft the timing will not be affected.
Currently in martin15s's garage:
2005 Renault Grand Scenic 1.9 dci
martin15s is offline   Reply With Quote Quick reply to this message
Old 21st July 2013   #3
KMathers
KMathers is
has no status.
Junior Member
I've had the same problem with my Megane except instead of eating the belt the pulley damper itself was worn so that there was a distinct knoocking sound when the engine was ticking over. I removed the pulley yesterday and have found there are a number available over the net.
I'm virtually certain I didn't move the engine since removing the pulley so I'm assuming I can just put a new pulley on without worrying about timing? Just don't want to make a "minor" job develop into a major one!
Is there anyone out there who can reassure me please?
KMathers is offline   Reply With Quote Quick reply to this message
Old 22nd July 2013   #4
martin15s
martin15s is
has no status.
Junior Member
When you have replaced the pulley, turn the engine over by hand for a couple of revolutions to ensure there is no valve to piston contact.
Old 22nd July 2013   #5
KMathers
KMathers is
has no status.
Junior Member
Thanks very much! Why didn't I think of that?
Reply
Tags
crankshaft, pulley
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
