Renault Scenic - Rear Child Locks Linked To Window Isolator - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Scenic
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Scenic
Reply
Thread Tools Display Modes
Old 12th February 2007   #1
barachello
barachello is
has no status.
Diamond member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Can anyone tell me how to turn off the child door lock on the rear doors in a 2004 Scenic II ??
Currently in barachello's garage:
2004 Scenic 1.5dci
barachello is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by barachello
2000 Megane coupe cab engine problem Engines barachello 1 767 29th October 2011 07:31 PM
Megane coupe cabriolet questions Bodywork barachello 0 889 25th August 2011 10:35 AM
Megane idle adjust Engines barachello 2 3507 18th April 2011 07:16 PM
Fuel Leak Engines barachello 0 913 10th April 2011 07:15 PM
Rung Spark Plug Engines barachello 9 1664 16th March 2011 12:57 PM
Sponsored Links
Advertisement
Old 12th February 2007   #2
Donald
Donald is
mad
Platinum member
Technical Supremo
Fishing the Sea Champion
Donald's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 11
Hi iam not sure if its the same as mine but there should be a small steel switch on the door itself beside the lock that moves from side to side lock and unlock i hope this helps
Currently in Donald's garage:
2005 Mercedes Benz C200 Classic SE Kompresser & 1998 Fiat Cinquecento Fire Sporting,some may say i could do far better?,i say i could do far worse.
Donald is offline   Reply With Quote Quick reply to this message
Old 12th February 2007   #3
Horatio
Horatio is
has no status.
Platinum member
Horatio's Avatar
Nominated 0 Times in 7 Posts
Nominated TOTW/F/M Award(s): 8
Alternatively, they may be linked into the rear window disabling switch on the driver's window control panel. That's how it's done on the Laguna. If the car has this system, then when the rear window switches are disabled, then the rear interior door handles are too.
Currently in Horatio's garage:
2010 Laguna III Initiale.
Horatio is offline   Reply With Quote Quick reply to this message
Old 12th February 2007   #4
ottoman
ottoman is
has no status.
Platinum member
Nominated 0 Times in 1 Post
Quote:
Yes it is as Horatio says in his post.
Ottoman
ottoman is offline   Reply With Quote Quick reply to this message
Old 12th February 2007   #5
SportTourer
SportTourer is
has no status.
Platinum member
SportTourer's Avatar
Yes - as both ottoman & horatio say.
However, there are also the "Normal" leavers as mentioned by donald - so you can permanantly enable/disable the locks, independant of the rear window control locks. This may be key operated ( using the "emergency key" from the card ) rather than just pushing a switch, you may have to turn the meachanism with the key.
__________________
Currently in SportTourer's garage:
2010 Laguna III SportTourer Initiale Tom Tom.
SportTourer is offline   Reply With Quote Quick reply to this message
Reply
Tags
child, isolator, linked, locks, rear, renault, scenic, window
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
