Modus 1.4 "Check emissions" - coil change didnt help - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 15th August 2013   #1
zanti
zanti is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hello
Check emissions light came up, exhuast smelled like petrol and engine jerking, googled it and fault coil pack was a common fault. Changed them all and put in new spark plugs at the same time. Car then worked all fine a few days before Check emissions light reappeared and started going poor again.
What is the next step, try to read out the error codes or maybe check the lambda sensor? Is it hard to replace yourself.
Thanks for every advice, feel stuck at this problem.
Currently in zanti's garage:
Renault Modus 1.4
zanti is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to zanti For This Useful Post:
mikegeegee (4th March 2015)
5 Lastest Threads by zanti
Modus 1.4 "Check emissions" - coil change didnt... Engines zanti 2 2843 15th August 2013 06:20 AM
Sponsored Links
Advertisement
Old 15th August 2013   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Modus 1.4 "Check emissions" - coil change didnt help
Try removing the spark plugs and check their colour - are they all of similar colour.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 15th August 2013   #3
zanti
zanti is
has no status.
Junior Member
Threadstarter
Hello again.
Problem is now solved: one of the new coils was faulty, replaced it and car again works. Checked the spark plugs and they seemed fine.
Thank you and hopefully the rest of the new coils work longer than a few days
Renault Modus 1.4
madnoel10 (15th August 2013)
Reply
Tags
change, check emissions, coil, modus
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
