Renault Scenic 1 - General Advice On Interior Water Ingress - Page 17 - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Scenic
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Scenic
Reply
Thread Tools Display Modes
Old 4th October 2010   #81
trish1
trish1 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Re: Renault Scenic 1 - General Advice On Interior Water Ingress
hiya i have a 2001 scienic andd have a massive water problem in both footwells we did the front window wiper area took all trim and wipers of and cleaned it then set about the drain holes on the sunroof we have got the passenger running free of water now but the drivers side is blocked solid half way down the tube i went and bought some curtain wire as advised in a earlier comment but that wont move it it solid and ideas please going of my head with this
trish1 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 24th October 2010   #82
abrahaj
abrahaj is
pleased with his 1999 Scenic he bought at the weekend!
Junior Member
I bought my January 1999 Scenic last week, and I love it, but noticed this weekend that I may have a water problem in the boot.
There are wet patches in the boot each side above the wheel arches, and the spare wheel is wet and the foam underneath is soaked.
I only have manual pop up sunroofs, but I presume I have the same drain holes that are mentioned in numerous threads on this subject?
Or is this a different problem I have here?
Currently in abrahaj's garage:
January 1999 "Lavender" Blue Scenic 2.0 RT!
abrahaj is offline   Reply With Quote Quick reply to this message
Old 28th October 2010   #83
nickynocks
nickynocks is
has no status.
Junior Member
try flushing it through with hot water and descaler!!!!
Currently in nickynocks's garage:
2005 grand scenic 1.9 tdi
nickynocks is offline   Reply With Quote Quick reply to this message
Old 5th November 2010   #84
scenicsimmo
scenicsimmo is
has no status.
Junior Member
This is my first post and I wanted to share the problem I had and the final solution.
The problem was water in passenger foot-well and a water sloshing noise from behind the fascia on the passengers side.
Having read the comments on this topic I carried out a number of checks which I considered relevant to my problem. Such as checking the sunroof drainage points. The sill drainage and the scuttle shelf drainage under the wipers. My problem was finally solved with the help from my Renault garage who pointed out that water from the air-con condenser should exit from underneath the car at a point roughly in the middle of the floor-pan. This sometimes blocks up and can also cause the water backup to enter the fan blower unit - hence the sloshing noise. The drainage point can really only be accessed safely by putting the car over an inspection pit or on a car lift. If you have to put the car into garage, as I did, allow costing for one hour labour and an additional hour if the fan blower housing has to be taken apart in order to remove water should it have gotten into that area. One pre check which could be carried out is to place the car on a flat dry surface and run the engine with the air-con switched on. If water exits from under the car then the drainage is okay. If not, then an air -con drain blockage could be the problem.
Hope this helps out anyone with a similar problem to mine. I will search out a friend with an inspection pit if it happens again to me as I prefer to DIY if possible.
scenicsimmo is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to scenicsimmo For This Useful Post:
Darkpowder (19th December 2010)
Old 23rd February 2011   #85
twonames
twonames is
has no status.
Member
This is all very useful.
I've had a 1997 scenic since almost new and never had a problem. t got taken away by a scrappy on Saturday.
My replacement 1998 scenic seems to be leaking from the aeriel hole. Plip stopped working today (just as well I had the emergency immobiliser code to hand) and then Mrs twonames noticed drips from above.
I shall get the goo gun out at the weekend
twonames is offline   Reply With Quote Quick reply to this message
Reply
Tags
advice, general, ingress, interior, renault, scenic, water
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
