Trafic M.A.F. readings loss of power. - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 5th September 2013   #1
mikessp
mikessp is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi all
I have been having a slight power loss issue with my van recently only above 2400 rpm,after doing some research on here its pointing toward the MAF sensor but having had a diagnostic done there were no codes for this.I'm trying to get a comparison to the data I have from my MAF sensor from the diagnostics test to see if this will show a marked difference as at £189 the sensor isn't a cheap fix and to change it only for the problem to persist would not be good spent enough on new gearbox recently what I need are the approximate idle air temperature and measured air flow readings to compare to mine to see if there is a vast difference. Mine was showing and air temperature of 38.7 degrees C and an air flow of 32.0 kg/h at 800 rpm.
Any help would be much appreciated.
Mike
Currently in mikessp's garage:
2005 renault trafic
mikessp is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by mikessp
Trafic M.A.F. readings loss of power. Engines mikessp 1 794 5th September 2013 12:02 PM
hello Welcome to RenaultForums HeatherJ 1 313 22nd November 2012 07:25 PM
Sponsored Links
Advertisement
Old 6th September 2013
petehall347
This message has been deleted by madnoel10. Reason: Spam and/or unwanted content
Old 8th September 2013   #2
mikessp
mikessp is
has no status.
Junior Member
Threadstarter
Re: Trafic M.A.F. readings loss of power.
Thanks for the reply but the fuel filter has been changed twice in the last 14 months due to the mileage I do so don't think there's an issue there. I just need some comparative data for the MAF sensor to rule that out but doesn't look like anyone's got that info .
2005 renault trafic
Reply
Tags
loss, maf, power, readings, trafic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
You may leave this blank
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Inactive Reminders By Mished.co.uk and FTP-Anime.com
