Renault Clio - 1.2 16v Misfire Information - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Clio
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Clio
Reply
Thread Tools Search this Thread Display Modes
Old 31st March 2007   #1
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 16 Times in 16 Posts
My Mood: Stressed
We had a 2002 Clio with the 1.2 16 valve (D4F,chassis code BO5) engine in it at work this week which had the engine management light on and the car was intermittantly misfiring.The codes stored in the ECU were refering to a misfire on cylinders 2 and 3.
We traced the fault to the coil pack(surprise,surprise!).The D4F engine is a bit of an odd ball engine as rather than using individual pencil coils it uses one coil to run all the cylinders.
The unit is held on with 3 T30 torx headed bolts (holes marked in picture below)and is very easy to replace.You just pull the leads off of the plugs,remove the multiplug from the coil and undo the three bolts.
A couple of things to bear in mind are the fact that the ends that go on to the plugs are made of very brittle plastic and easy to break,so when changing the plugs,be very careful when removing the leads.Also,the plugs are a strange size and a normal plug socket won't fit them.I used a 14mm deep socket,but you have to be careful as proper plug sockets are designed to avoid damaging the ceramic insulation,but a normal socket isn't.......
The leads are built into the coil pack,so if you manage to break a lead when changing the plugs,you have to replace the whole unit!.Don't panic though,as the whole thing from Renault is only around £35.Also,the leads are numbered so you can't mix them up,but be aware that the French number the cylinders from the flywheel end,rather than the front of the engine like everyone else,so number 1 cylinder is the one nearest the gearbox,number 4 is one nearest the cambelt end.
If you do have to replace a coil pack,it is always advisable to replace the plugs at the same time.
Hope this helps someone out in the future.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2003 Alfa Romeo 156 2.4 JTD Sportwagen (estate to you and me!), 2004 BMW 330d Touring in many,many pieces, 2002 Alfa Romeo 147 2.0TS Lusso soon to also be in many pieces.....
Lagdti is offline   Reply With Quote
The Following 7 Users Say Thank You to Lagdti For This Useful Post:
billythekid (13th May 2011), Dal22 (16th October 2010), exmacadato (31st March 2013), holliej (9th October 2012), JayHS (21st May 2011), kramer250 (5th June 2010), olic123 (7th February 2011)
5 Lastest Threads by Lagdti
40,000th Post......:eek: General Chat excavator 57 878 3rd May 2013 02:28 PM
Sponsored Links
Advertisement
Old 6th April 2007   #2
twingo
twingo is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Is there a photo of where on the engine block the coil pack is situated?
Currently in twingo's garage:
2001 Twingo 16V "Green Fee"
twingo is offline   Reply With Quote
Old 6th April 2007   #3
Lagdti
Lagdti is
Veteran Member
Technical Supremo
Threadstarter
Lagdti's Avatar
My Mood: Stressed
I'm afraid not,but if you follow the plug leads it will be at the other end of them.On the Clio I worked on it was bolted on top of the left side of the engine as you looked at it from the front.
Old 6th April 2007   #4
twingo
twingo is
has no status.
Junior Member
In that case my question is now:
"how do I get the grey cover off from over the spark plugs?"
The Following User Says Thank You to twingo For This Useful Post:
Old 11th June 2007   #5
jeff_porter
jeff_porter is
has no status.
Junior Member
From Renault is only around ***163;35:...
Do you have a part number for this?
Currently in jeff_porter's garage:
Clio 1.2 2003
jeff_porter is offline   Reply With Quote
Reply
Tags
16v, clio, information, misfire, renault
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
