Renault Clio - 1.2 16v Misfire Information - Page 4 - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Clio
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Clio
Reply
Thread Tools Search this Thread Display Modes
Old 30th March 2010   #16
rufnek2kx
rufnek2kx is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Re: Renault Clio - 1.2 16v Misfire Information
I have a 1.4 mk2 clio. I was just wondering whether a dodgy TDC sensor can cause just one piston to fail on its own? My thermostat has been leaking a lot lately and I think I read that the TDC sensor is located right beneath it. If some water/coolant has gone into the sensor, would it affect all the pistons together or can it isolate one?
I have checked the coil for the misfiring piston and it sparks fine. replaced the spark plug with a bosch one aswell and still no response from piston 4
Im really hoping its a cheap fix
Currently in rufnek2kx's garage:
Renault Clio mkII Alize 1.4i 8v 5Dr V reg E7F
rufnek2kx is offline   Reply With Quote
Sponsored Links
Advertisement
Old 23rd April 2010   #17
hunter21
hunter21 is
has no status.
Junior Member
hi just wondering how do you tell if he spark leads are gone i have a clio 1.2 16v 2005 every now and then when driving it will loose power but if you put down acelerater it picks back up ive look under the bonnet in the dark and one of he leads is sparking thanks
Currently in hunter21's garage:
renault clio 1.2 expression 2005
hunter21 is offline   Reply With Quote
Old 23rd April 2010   #18
mathaz_2003
mathaz_2003 is
has no status.
Junior Member
my 1.2, 16v, clio campus sport had a similar issue... changed spark plugs and coil pack and ran fine for around 3-4 days (following diagnostics test)...
now the car is very poor in acceleration and wont go above 50-60mph... any ideas?
revised diagnostics test is coming back with a knock sensor issue
would appreciate your help and any swift reply, as its currently costing me a small fortune...
thanks, Graeme
Currently in mathaz_2003's garage:
1.2, 16 valve, clio campus sport, 56 plate
mathaz_2003 is offline   Reply With Quote
Old 12th May 2010   #19
rufnek2kx
rufnek2kx is
has no status.
Junior Member
Quote:
I ruled out my leads by changing them around and checking whether the misfire was still on the same cylinder or whether it had moved. I was a bit lucky in the fact that the misfire is happening on the cylinder closest to the coil pack, so even when I changed the leads they would still fit rather well.
Old 17th May 2010   #20
frankster
frankster is
has no status.
Junior Member
Quote:
Originally Posted by dale521 View Post
i have a clio 1.2 8v a while back timing belt snapped so head head gasket done new valves got it all togeather fired up perfect got it through test come to fire it up this morning and its on 3 cylinders pot 4 has gone down i have changed plugs changed ht leads and changed coil pack and also changed injector 4 for injector 1 but still same as any one any ideas why this may be and there is compressing in pot 4 need help and its a 2002
Hi Dale. I had similar problem and when I swapped injectors it seemed ok to, I did notice spray pattern was poor though, but checked in an injector spray booth I notice the said injector was producing a poor spray and fuel delivery rate was well under the other 3.
I bought a new injector at renault £66 and all was well.
Hope this helps you.
On the other hand di you check the tappets or manifolds for air leaks?
Currently in frankster's garage:
2001 clio II 15DCI
frankster is offline   Reply With Quote
Reply
Tags
16v, clio, information, misfire, renault
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
