Camshaft Timing Marks Not there - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 22nd April 2007   #1
merky
merky is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi. I have a Laguna II 1.9dci and have been having some problems with it smoking..
Anyway, I recently done the cambelt and put a new one on exactly the way the old one came off..
I have done many cambelts in the past, but this engine does not seem to have a mark on the engine backplate to match the camshaft. I have the pin in the crankshaft so I know this is at top dead. The camshaft pulley has a round dot on it so I can get this mark, but there is suppose to be a mark on the back plate, but there isn't??
I could be a tooth out and not realise it, if it was would it damage the engine, would I get smoke as the timing would be wrong, although the car runs lovely, pulls away no problem..
Are there any marks on the camahafts themselves if I took the rocker cover off???
Cheers
Currently in merky's garage:
2002 Renault Laguna II Tourer 1.9dci
merky is offline   Reply With Quote Quick reply to this message
The Following 2 Users Say Thank You to merky For This Useful Post:
hendrik lubbe (26th February 2012)
5 Lastest Threads by merky
Grand Scenic 1.9dci does not start Engines merky 2 798 25th November 2013 09:17 PM
Knocking from front on rough roads Steering and Suspension davesss 3 1351 13th October 2007 10:16 PM
Laguna II 1.9dci takes ages to start Engines madnoel10 4 1776 1st October 2007 09:20 PM
Laguna II 1.9dci 2002 Low compression Engines dazid1 12 5694 7th May 2007 09:54 PM
Camshaft Timing Marks Not there Engines tankpzk6 8 8535 22nd April 2007 11:20 PM
Sponsored Links
Advertisement
Old 23rd April 2007   #2
Donald
Donald is
mad
Platinum member
Technical Supremo
Fishing the Sea Champion
Donald's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 11
Hi yes i also believe the mark should be on the back plate or the belt cover plate i hope this helps all the best Donald
If you have no luck phone Renault and ask to be put through to technical services and ask them iam sure they will help iam for always doing this cheers
Currently in Donald's garage:
2005 Mercedes Benz C200 Classic SE Kompresser & 1998 Fiat Cinquecento Fire Sporting,some may say i could do far better?,i say i could do far worse.
Donald is offline   Reply With Quote Quick reply to this message
Old 23rd April 2007   #3
tomandjo
tomandjo is
has no status.
Member
Some modern engines don't have timing marks and therefore a jig may be required to help set the timing correctly.
Tom
Currently in tomandjo's garage:
2001 Renault Laguna II 1.9DCi
tomandjo is offline   Reply With Quote Quick reply to this message
Old 1st June 2007   #4
tankpzk6
tankpzk6 is
has no status.
Junior Member
Hi Donald,
I was just looking for the location of the cam pulley marks on my 1.4e Megan when I came across your post
The belt went & I am trying to fit a new one but I have no idea where to set the cam can you give us a clue please
Tank
tankpzk6 is offline   Reply With Quote Quick reply to this message
Old 1st June 2007   #5
goon
goon is
has no status.
Member
The hard and fast answer to this is that there are no timing marks!!!!! Renault use a cam locking tool that goes on the opposite side to the cambelt. When set correctly, there are two notches in the camshafts that sit just below level to the camshaft cover line. The tool then screws into a hole and locks these two in place. the crank shaft pulley is held by a screw in pin that slots in to h hole by the sump near to piston one. This holds the big end in place and is a bloomin' tricky job because, if you get it wrong, you'll screw into the web of the big end and then it'll slip. Don't, whatever you do, unscrew the campulleys. They have no locating method such as a woodruff key and are purely an interference fit. If you are going to take them off, then draw a marking line on each from the pulley, through the web, onto the camshaft and upto the block.
That having been said, I don't think your problem is the timing as the ecu would have a fit if the timing was out and the engine is a close intereference job, so your valve would be shot in an instant. I suspect that your turbo may well be gone as this is a common fault with the DCI. similarly, have you used a diesel flush in it?
Currently in goon's garage:
Citroen C4 VTS - The Laguna has moved on to pastures new!
goon is offline   Reply With Quote Quick reply to this message
Reply
Tags
camshaft, marks, timing
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
