Renault Laguna II - Interiors - Door panel removal - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Laguna
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Laguna
Reply
Thread Tools Display Modes
Old 27th April 2007   #1
iantomos
iantomos is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Angry Renault Laguna II - Interiors - Door panel removal
Can anyone tell me how to take off the front door panel as I need to lube the runners on the front windows. Have tried spraying WD40 & fairy liquid with the window down. Cured the nearside squeak, offside window still sounds horrible and it's starting to **** me off!! Oh joy...
Currently in iantomos's garage:
2001 laguna II 1.9 dci
iantomos is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by iantomos
Renault Laguna II - Interiors - Door panel removal Laguna bpowell555 5 29758 27th April 2007 04:35 PM
Laguna II front door panel removal Interiors eggsy 2 9220 20th April 2007 09:33 AM
Renault Laguna II - Slow & noisy windows Interiors iantomos 2 2370 5th February 2007 08:58 AM
Laguna II sport tourer tailgate problems Bodywork iantomos 2 1805 17th October 2006 12:21 PM
Sponsored Links
Advertisement
Old 27th April 2007   #2
chris m
chris m is
tired but hopeful
Let's be carefull out there
chris m's Avatar
Nominated 0 Times in 4 Posts
Nominated TOTW/F/M Award(s): 3
Once you have undone all the screws that hold the fittings on there will be plastic clips between the card and the door itself, pop them out with a blade. The skin on my Clio is also hung from the top so it lifts up to remove. Also you may find it is stuck to the door with a waterproof mastic. Under this is normally a plastic sheet to stop water ingress from door to car so remove carefully.
__________________
Currently in chris m's garage:
2000 Scenic 2.0 16v Monaco, Peugeot 207sw 1.6 HDi
chris m is offline   Reply With Quote Quick reply to this message
Old 27th April 2007   #3
bpowell555
bpowell555 is
now part of the Single Mass Flywheel club
Platinum member
bpowell555's Avatar
cheers chrism!
Currently in bpowell555's garage:
2002 Renault Laguna II 2.2dCi Initiale, 1990 E30 325i Touring (Bavarian Tigzwerken Express)
bpowell555 is offline   Reply With Quote Quick reply to this message
Old 7th May 2007   #4
bpowell555
bpowell555 is
Platinum member
bpowell555's Avatar
Quote:
Does it matter if you don't replace the mastic? Will there be water ingress or more noise?
hmmmm...?
Old 8th May 2007   #5
davesss
davesss is
Calm Cool and Collected
Tourerman
davesss's Avatar
Nominated 0 Times in 2 Posts
I have just greased the runners on my Lag 11 front doors.
There is no plastic sheet fitted under the door covers on the Lag 11.
Carefully prise off the Black plastic door mirror cover inside the door, comes off easy.
There is no need to prise out the window switches.
Prise out the electric mirror switch and disconnect plug, easy.
Undo the screw for the door handle, screw under plastic cap.
undo 2 screws under the bottom of the panel.
Carefully use a flat screwdriver to lever off the panel, 2 or 3 plastic lugs each side of the panel.Lift the panel up and remove.
Remove the door light bulb asembly and the inside door handle cable, this will give you enough clearance to oil the runners.
__________________
A problem well stated is a problem half solved !
Currently in davesss's garage:
2002 Laguna Sports Tourer 1.8 Dynamique Moondust VF1KGOB, Fiat Siecento Micheal Schumaker, Kawasaki KLE M/Cycle and a cheap Mountain Bike.
davesss is offline   Reply With Quote Quick reply to this message
Reply
Tags
door, interiors, laguna, panel, removal, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
