Headlight not working. - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 17th November 2013   #1
Gav86
Gav86 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi guys,
Reg: 53 Megane II 1.5dci Estate
I read a post on here a couple of weeks ago regarding both headlights blowing together as it seemed this was my situation!! After investigating, it seemed only 1 had blown as the Near Side bulb still looked in tact.
After replacing both bulbs with new OSRAM 'Night PLUS', and removing the Circuit Board to potentially dry out any damp, only the O/S headlight appears to work!
The problem I've found is that after checking & changing around the 2x 10Amp headlight fuses, there doesn't seem to be any life coming from the circuit board! You can normally notice a tiny blue spark when pushing in a fuse but there doesn't appear to be any signs of life..
My question therefore is where do I continue my search for a break in the system? Are any wires accessible prior to the Circuit Board and if so, which one (Colour)?
NB: I had a family member (Familiar with circuit boards) check the solders and to see if there was any faults but a visual check came back ok, not to say for certain that the board isn't at fault.. But are there any other suggestions?
Thanks in advance guys
Gav
Gav86 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Gav86
Headlight not working. Electronics lancs dave 3 861 17th November 2013 08:26 AM
Sponsored Links
Advertisement
Old 17th November 2013   #2
lancs dave
lancs dave is
struggling to get in gear
Platinum member
Technical Supremo
lancs dave's Avatar
Nominated 13 Times in 26 Posts
Nominated TOTW/F/M Award(s): 12
Re: Headlight not working.
A fuse will only give a spark if there is enogh current flowing round the circuit.
You can still have 12v available but it might have no where to go.
If you still have access to the fusebox and still have battey fitted ect, check these.
Check for power at both sides of both fuses with lights switched on.
Check the connections on the connector marked PPA which is next to those fuses.
I get dipped headlamp fuses to be
8C for right side
8D for left side
If you get power at both fuses, check for power at bulb connection.
Check for earth at bulb connection.
Currently in lancs dave's garage:
Less rubbish now I've been to the tip.
lancs dave is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to lancs dave For This Useful Post:
Gav86 (20th November 2013)
Old 19th November 2013   #3
Gav86
Gav86 is
has no status.
Junior Member
Threadstarter
Thumbs up Re: Headlight not working.
Hello Dave,
Thanks a lot for this mate. I borrowed a volt meter and checked the fuses etc, I then checked the connector block at the bulb and noticed there was barely a reading so on checking the PPA connector above the headlight fuses 'as you sudgested', it turns out it had a loose connection.
After disconnecting, giving it a clean and a jiggle, both headlights now work perfectly..
Great job, thank you
All the best
Gav
Old 19th November 2013   #4
lancs dave
lancs dave is
Platinum member
Technical Supremo
lancs dave's Avatar
Well done on the fix Gav.
Glad it helped.
Reply
Tags
headlight, not working, working
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
