Crankshaft removal - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Crankshaft removal
Engines
Reply
Thread Tools Display Modes
Old 20th November 2013   #1
hannesbekker
hannesbekker is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Crankshaft removal
Hi, does anyone know how to remove the crank pulley and the no1 main bearing to get the crankshaft out?
hannesbekker is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by hannesbekker
Crankshaft removal Engines Prickleypear 3 1170 20th November 2013 05:01 PM
Sponsored Links
Advertisement
Old 20th November 2013   #2
Delfine
Delfine is
has no status.
Diamond member
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 2
Re: Crankshaft removal
Quote:
More engine information would make it easier for forum members to answer your question . As what your working on may not necessarily what your showing as being in your garage ?
Currently in Delfine's garage:
3.0 V6 Laguna Initiale, 2.0 IDE Megane Convertible Mk1 phase2
Delfine is offline   Reply With Quote Quick reply to this message
Old 21st November 2013   #3
hannesbekker
hannesbekker is
has no status.
Junior Member
Threadstarter
Hi Delfine
I'm working on my Megane ii 1.9 dCi
Old 21st November 2013   #4
Prickleypear
Prickleypear is
the fruit of a cactus from South Africa
La sola lupo
Prickleypear's Avatar
Hallo Hannes
I am assuming some things here so correct me if i'm wrong,I assume you have the engine out of the car, and i assume you are not able to get the bolt on the pulley loose because the crank keeps turning and i assume its a F9Q Engine.
First of all, on the side of the block facing the radiator about 60mm from the flywheel side, there is a plugbolt its about M8 or M10 if i remember correctly, if you remove the plug you can insert a locking tool ( a correct size rod will do) but watch out not to damage the threads.
If you have removed the other main bearing caps it is better to replace them before trying to loosen the crank bolt so you dont damage anything.
Alternatively you will have to lock it on the flywheel teeth but again be careful not damage anything
__________________
"Curiosity is the key to creativity" Akiro Morita Sony
Hasta mañana
Currently in Prickleypear's garage:
'85 Renault 11TS, '97 Megane 2lt 8v RXE, '96 Extra 1.9d, '95 Merceds C220, '64 Fordson Supermajor Tractor
Prickleypear is offline   Reply With Quote Quick reply to this message
Reply
Tags
crankshaft, crankshaft pulley, removal
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
