Water leaking into car footwells - Page 3 - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Espace
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Espace
Reply
Thread Tools Display Modes
Old 25th November 2007   #11
eggsy
eggsy is
has no status.
Diamond member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Wet footwells on my Mk1 lag were down to the plastic cover under the door liners coming away. my friend had water sloshing around in his Mk11 lag and it was in the doors as the drain plugs were blocked.
__________________
Cornwall the place to be!
Currently in eggsy's garage:
02 laguna 1.9 dci
eggsy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 29th November 2007   #12
Babyboaty
Babyboaty is
has no status.
Junior Member
I've got water sloshing round in the passenger door of my Lag II also. The door has a rubber drain plug on the underside, and I have to routinely drain the doors from water. I look like a prat if I'm seen doing this.
Surely the doors shouldn't accumulate water in the first place.........hence the fact that they need to be drained manually, rather than a drain point existing but getting blocked up.
Any ideas where the water is ingressing, so I can possibly prevent it from entering in the first place.
Currently in Babyboaty's garage:
Laguna II 1.9dCi Dynamique
Babyboaty is offline   Reply With Quote Quick reply to this message
Old 29th November 2007   #13
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Hi Babyboaty - if you look closely behind the rubber strip along the bottom of the door there are long slim elongated drainholes. Water runs out of mine all the time - all cars get water ingress via window surrounds etc - its just a question of letting the water out quicker than it comes in.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 29th November 2007   #14
Babyboaty
Babyboaty is
has no status.
Junior Member
Thumbs up
Quote:
Well that would explain it, nice one!
Old 29th November 2007   #15
bramble1979
bramble1979 is
has no status.
Junior Member
Thumbs up Same Prob With Megane II and sloved it!!
Hi not sure if this helps but had the same problem with my 2003 Megane.
Turned out to be the drain pipe from the climate control, which had come off. As a result all excess water as pooling in the foot wells. Ha been like it for several months judging by the amount found.
Was a pain to fix though as most of the dash had to be removed.
Hope this helps
Currently in bramble1979's garage:
2003 Renault Megane II 1.6 Dynamique
bramble1979 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to bramble1979 For This Useful Post:
boboslobodan (11th August 2011)
Reply
Tags
car, footwells, leaking, water
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
